Hello,
I've a problem on a revision of a custom board that drives stepper motors. This board originally had a single power supply source from an AC 110V . Internally there's a rectifier plus capacitance and DC result goes to power side (mosfets and stepper phases) and a switching regulator that powers logic at 12V. This board never had particular issues.
After revision, power side and logic power side were separated. There's same AC that power mosfets but no longer the internal switching, now this one is powered by external DC at 24V. This two power supply sources have a common ground on PCB between rectifier low side output and 24V's gnd.
What I encounter now is a huge noise on 24V and on outputs from devices that are powered from this 24V that generate several problems.
Here's some images to explain:
I'm trying to figure out how to reduce this noise. If I should filter and how the 24V input or place a filter between the joint point of this two grounds (AC and DC).
Looking for any help.
