Author Topic: Humidity sensor  (Read 2582 times)
Offline DavidDLCTopic starter
Humidity sensor
« on: December 28, 2011, 02:52:02 am »
What type of sensor is this ? Capacitive ? Resistive ? Other ?
Offline gxti
Re: Humidity sensor
« Reply #1 on: December 28, 2011, 03:15:41 am »
I would assume that it is capacitiive, because the overlapping plate structure looks sort of like a capacitor. Multiple elements in parallel increases the capacitance for ease of measurement, smooths out errors from manufacturing tolerances, and exposes the sensor to more air. As I understand it most general-purpose hygrometer elements are of the capacitive type. You're going to need more information than that to interface to it though. A datasheet is a must.
Offline johnmx
  • Country: pt
Re: Humidity sensor
« Reply #2 on: December 28, 2011, 10:52:48 pm »
The LDRs (light dependent resistors) have a similar structure and are resistive sensors....
Best regards,
johnmx
Offline qno
Re: Humidity sensor
« Reply #3 on: December 29, 2011, 07:44:44 pm »
they look like resistive humidity sensors.
You can buy them at Conrad here in Europe.
You can also roll your own by sticking 2 electrodes (copper wires) into gypsum.
The response will be slow depending on size.
Make them too small and they will easily break.
Why spend money I don't have on things I don't need to impress people I don't like?
