Author Topic: HVAC/PLC Universal Input Design  (Read 2719 times)
Offline StuntMonkehTopic starter
« on: January 10, 2014, 03:59:22 pm »
I have been working on a universal input design to be used with an MCU from some existing schematics I found.
I was lucky enough to find the resistor network to setup the input in a datasheet from one controls manufacturer but I have been trying to figure out what other components were required to make it resistant to the expected voltages without killing the MCU ADC input.
Is what I have done so far correct, can anyone suggest any improvements upon this?
Re: HVAC/PLC Universal Input Design
« Reply #1 on: January 10, 2014, 04:14:52 pm »
Other than the LM358 being the wrong choice with the supply voltage you have all else will work and survive pretty much anything up to mains being applied ( except in current mode where the resistor will die a fast death) to the input.
« Reply #2 on: January 10, 2014, 04:37:45 pm »
Yes input to expect up to 24vAC no higher.
I wasn't sure what type of opamp, I need to really investigate that part further although the datasheets I can find indicate most LM358's are 3.0v to 30v.
Can anyone point me in the right direction of how to choose correct opamp selection.
Offline orion242
« Reply #3 on: January 10, 2014, 04:38:52 pm »
That diagram looks identical to the inputs on the controllers I use.
What brand did you hock that from?
« Reply #4 on: January 10, 2014, 06:07:15 pm »
LM358 may be rated from 3V but at 3V it can barely do 100mv in the middle. You need a rail to rail input and output opamp to work off 3V properly.
« Reply #5 on: January 10, 2014, 09:27:34 pm »
Am I on the right track if I read this?http://www.ti.com/lit/an/sloa098/sloa098.pdf
