Author Topic: HVDC Capacitor Charger Help  (Read 3525 times)
Offline GoatureTopic starter
  • Country: no
« on: June 06, 2014, 07:48:22 pm »
Hello! I'm working on a HVDC capacitor charger. I've made it work, and it charges the capacitors to around 400V. This is the circuit:
... and here's my problem:
When i discharge the capacitors over a large inductor (you can probably figure out what i'm doing here :P) different parts of the circuit fails; specially the 555 and the mosfet. I've concluded that it's probably caused by a large negative ripple the second the inductor is discharging. How can i protect my circuit from this ripple, and still get it to charge as it sould? (U2 and U3 are connected to the capacitors)
Bonus round: Do you have other improvements for the circuit? :)
Thanks! :D
« Last Edit: June 06, 2014, 07:50:13 pm by Goature »
Offline johansen
Re: HVDC Capacitor Charger Help
« Reply #1 on: June 06, 2014, 07:55:57 pm »
you have to disconnect the capacitor from the charging circuit.
when you discharge a capacitor into an inductor, the energy is conserved, the current will continue to flow through the boost diode and the mosfet body diode.
most likely neither of which can handle the current, and the leakage inductance of the circuitry means some of that voltage will blow up everything else as well.
  • Country: no
« Reply #2 on: June 06, 2014, 08:01:47 pm »
...the current will continue to flow through the boost diode and the mosfet body diode.
That's true! I forgot to mention that the diode also blows up often. I guess a hefty relay of some sort would help? Maybe a smaller contactor? Got to look into that! :)
« Reply #3 on: June 06, 2014, 08:08:10 pm »
Glaring omissions to manage the Back EMF are:
Snubber
Diode ratings ?
Series diode before L1
IC de-coupling cap
EDIT
And R3 4R7
R4 1K
« Last Edit: June 06, 2014, 08:16:16 pm by tautech »
Avid Rabid Hobbyist
  • Country: no
« Reply #4 on: June 06, 2014, 08:39:57 pm »
Diode ratings ?
D1 is a MUR1560 (http://www.onsemi.com/pub_link/Collateral/MUR1520-D.PDF):
VRRM: 600V
Average current: 15A
D2 is a simple 1N4007 (1000V, 1A)
Thanks for the suggestions! :D
Offline max_torque
    • bitdynamics
« Reply #5 on: June 06, 2014, 09:04:54 pm »
For anything like this^^ you can't beat a proper physical "disconnect".  Use a relay with suitable rating (and contact gap!) to break both the +ve and ground lines to the HVDC cap and firing circuit
Offline doktor pyta
    • Vintage Test Gear
« Reply #6 on: June 06, 2014, 09:37:56 pm »
Hi
If You want to obtain high efficiency it's better to have current- control SMPS IC.
Similar thread was discussed few years ago on a Polish forum.
Below link.
http://www.elektroda.pl/rtvforum/topic556770-0.html
The guys are helping each other and the final schematic is the "schemat4.gif".
You should use Google translator, but basically schematics are universal language. Like music...
  • Country: no
« Reply #7 on: June 09, 2014, 07:35:04 pm »
Below link.
Very interessting! I'm going to have a look at that! :)
