When out=HIGH, want lower comparator's '-' input (TripL) to go lower. This means the output transistor is 'OFF' so the pull-up has a chance of working.
But taking TripL low ALSO pulls TripH low. This could cause a valid input near to TripH to appear invalid, causing the upper comparator's transistor to turn on.
The output is effectively "wired-NOR", with 00-->High for valid input inside the thresholds.
TripL < U ---> Lower comparator sees valid input
"OR"
U < TripH ---> Upper comparator sees valid input
So if out=HIGH, we want hyteresis to pull TripH 'upwards', and TripL to move downwards.
Is there a neat, simple solution?
