Author Topic: Hysteresis Loop Plotter for Scope  (Read 907 times)
Offline LaserSteveTopic starter
« on: February 28, 2026, 02:59:17 pm »
Attached is from my archives
I used to bike 17 miles each way to the local  library, and then sneak into a university library  when I was a kid to read electronics and learn. Saturdays..
This was BI, Before Internet.  Happy way to escape the house, but if I got a tire  puncture and was away from a "pay" phone, life could get interesting.
Led to a career, thanks to a College Librarian who noted the teenager returned the books to the shelves, sorted her shelves, cleaned up the card catalog,  and unlike others, was not there for mischief. I was a  library aid in Junior High and High School.   I knew what and where to raid, and how to play nice.  I may have ignored a no one under 18 admitted sign while wearing a dress shirt for camo.
I soon had a pass and a admission letter to the campus PD as a welcome guest.  May her memory be a blessing.  Her kindness certainly was a blessing. I attended her retirement party many years later as a staff member with a degree.   LOC Code TK781... I remember that..
But I digress.
Prior to the PDF, we had these things called photocopiers. I just scanned it in for an amusement.
This is from my collection.... From the EDN design ideas, Author D.A. Zinder,  and  probably Markus's "Circuit  Ready Reference "
XY plots a B-H curve on a scope. 2771825-0
Discuss:
« Last Edit: February 28, 2026, 03:08:24 pm by LaserSteve »
"I calculated the stored energy, and it is enough to play the Dance / DJ Extended edition of "Baby Shark" in all 100 headsets for the production floor team simultaneously over 100,000 Times."
Well, I had to explain it to my boss, somehow.  He's an Accountant,  not a PHB.
The following users thanked this post: pardo-bsso, 2N3055, ch_scr
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
Re: Hysteresis Loop Plotter for Scope
« Reply #1 on: February 28, 2026, 04:06:51 pm »
can be done with just an RC integ. and CS res.
No amps needed
j
The Internet Dinosaur..
passionate about analog electronics since 1950s
« Reply #2 on: February 28, 2026, 04:47:02 pm »
JonPaul,
Care to share a sketch?
Steve
The following users thanked this post: jonpaul
Offline TimFox
« Reply #3 on: February 28, 2026, 04:52:12 pm »
In the late 1960s, in an undergraduate physics lab, I did the “Rowland Ring” experiment to trace the hysterisis loop the old-fashioned way: reversing the primary current with a Leeds & Northrup knife switch and integrating the secondary current with a ballistic galvanometer.
Offline mawyatt
« Reply #4 on: February 28, 2026, 06:13:10 pm »
Like those great EDN Design Ideas from yesteryear :-+
Fond memories indeed!
Remember begging my parents to take me to the library as a 8 year old to read every book I could find on electricity, was fascinated by it over 70 years ago, still am today :-+
Best
~Wyatt Labs by Mike~
Offline MariuszD
« Reply #5 on: February 28, 2026, 09:50:21 pm »
In the 21st century, it can be done more easily. It is enough to apply a rectangular waveform to the winding. Record the voltage and current waveforms, copy the data to a computer, and calculate the rest on the computer.
Offline jonpaul
    • IEEE Spectrum
« Reply #6 on: March 01, 2026, 05:48:16 pm »
Laser Steve et al:
2772573-0
A current shunt or sensor in series with the Lut
Use a second wdg or "search coil" typically 10T wound around a core leg. Or if a transformer, just a sec wdg.
That voltage is integrated bya simple R-C integrator, eg 1M/100 nF
Scope is in  XY mode
If a digital scope can nix the RC integ and just use the scopes math to intege.
See 1960s texts on "Electronic Measurements" and Hunt and Stein "Static Electromagnetic Devices (my CCNY text of 1960s...)
Have an absolutely fantastic Day!
Jon
Offline MariuszD
« Reply #7 on: March 01, 2026, 05:56:17 pm »
I am interested in the integrator circuit, does anyone know why a T circuit and an additional capacitor were used in the reset circuit?
The diagram shows three capacitance values, but there are only two capacitors, so it is unclear what value the integrator capacitor has.
« Reply #8 on: March 02, 2026, 06:32:26 pm »
So, the clever designer created a network that prevents integrator windup while adding some roll-off and centering.  It is a frequency dependent "leak" across the integrating capacitor. It will also roll off the corners of any sharp snaps in the scope plot. Given the nature of the ancient op-amp, without the network it would drift to one of the supply rails in seconds.  I had GPT run the plots, so no promises of accuracy.
Bode Plots
2773073-0
« Last Edit: March 02, 2026, 06:37:06 pm by LaserSteve »
Offline MariuszD
« Reply #9 on: March 04, 2026, 05:42:39 am »
I still can't understand what benefit a 10uF capacitor provides between the 47kΩ resistors. I did a simulation with it and without it, and the graph lines almost overlap.
It is also not clear to me whether the integrator capacitor is 50uF or 1uF. Both numbers are close to the capacitor, and it's hard to determine which one is significant. If it had 1uF, then using a 10uF capacitor between the 47kΩ resistors would change the characteristics.
2773629-0
2773633-1
EDIT:
I tried with a 1uF integrator capacitor and I see a case where it makes sense. The cutoff frequency is boosted, and for some frequencies, the integrator works better. But for very low frequencies, ringing occurs.
2773729-2
2773733-3
2773737-4
« Last Edit: March 04, 2026, 12:51:26 pm by MariuszD »
