Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
I made a browser tool to visualize switched reluctance motor coil configurations
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: I made a browser tool to visualize switched reluctance motor coil configurations (Read 319 times)
dusan
Regular Contributor
Country:
on:
May 16, 2024, 02:05:02 pm »
I needed a PCB based motor and I needed it to rotate slowly so I needed higher amount of coils/poles than usual 3 coil + 2 poles but it was really hard to wrap my head around it because depending on the sizes and ratios and integer factors it may not even work, or may be chaotic etc... I specifically wanted to go up to 12 coils/poles which gives 144 total combinations out of which only 92 are valid. I chose switched reluctance motor instead of BLDC motor because it feels like it might be less sensitive to low tolerances and janky builds.
Here is the tool:
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html
Here are all configurations for given amount of coils/poles:
https://dvhx.github.io/switched-reluctance-motor-configurator/combinations.html
Especially interesting are combinations where there are multiple coils but can be doubled or tripled, for example:
- 6c2p (3 real coils, 6 steps) -
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html?coil_count=6&pole_count=2
- 9c3p (3 real coils, 9 steps) -
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html?coil_count=9&pole_count=3
- 12c3p (4 real coils, 12 steps) -
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html?coil_count=12&pole_count=3
- 12c8p (3 real coils, 24 steps) -
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html?coil_count=12&pole_count=8
- 12c9p (4 real coils, 36 steps) -
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html?coil_count=12&pole_count=9
- 12c11p (maximum of 132 steps) -
https://dvhx.github.io/switched-reluctance-motor-configurator/index.html?coil_count=12&pole_count=11
Last Edit: May 18, 2024, 04:59:33 am by dusan
Logged
aliarifat794
Regular Contributor
Country:
Re: I made a browser tool to visualize switched reluctance motor coil configurations
Reply #1 on:
May 17, 2024, 06:02:38 pm »
I was trying this. Do we need to click 'step' to get our final result? I just put some random values and pressed 'step'. The diagram changed according to the parameters and after clicking on 'step' it said 'poles are overlaping'.
Logged
dusan
Regular Contributor
Country:
Reply #2 on:
May 18, 2024, 04:58:16 am »
I fixed it. When you change configuration it will now show result immediately. Step button is to see "animation".
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
