Here is a Wein bridge oscillator which I have built and used many times. The FETs serve as pure diodes compensating for temperature changes. I can blow a hair dryer on this until all the components reach 80C and still the amplitude of the sine wave remains very steady. The frequency depends on the RC, I use qood quality Rs and Cs and it is also dead steady. The above circuit is at around 200KHz.
I would like the frequency to vary between two limits, say +/- 10% of the fundamental, so in the case above I would like it to go from 180KHz to 220KHz, more or less. I have a 555 square wave with a period of 1.5 seconds, so that would be ideal to switch frequencies on each of the 555's pulses.
An easy way to do this would be to alter the R1/R2 around the 6.8K value, eg 6.2K, 6.8K, 7.5K. Can anyone suggest the circuitry required to achieve this?
