Author Topic: Ideas needed for a Ping and Reboot unit,  (Read 4106 times)
Offline akanowitzTopic starter
« on: August 28, 2013, 04:58:06 am »
Hi everyone,
Hoping you can help out, I am looking for a device or something I can run on a PC that will ping an IP every 15 mins or so. If it does not get a reply , it must power cycle a USB relay or similar to cut power to that device being pinged and allow it to restart. Any ideas would be appreciated.
Many thanks
Alan
Offline Psi
Re: Ideas needed for a Ping and Reboot unit,
« Reply #1 on: August 28, 2013, 05:31:27 am »
Do a google search for PC watchdog relay
Online IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #2 on: August 28, 2013, 10:55:48 am »
I did more or less what you're asking for but using an Arduino. I needed to monitor a Draytek modem to see if it had hung, and if it had it would automatically recycle the power to it via a relay.
http://www.ianjohnston.com/index.php?option=com_content&view=article&id=75:modemmonitor&catid=3:hobbies&Itemid=8
- Monitor Status
- Current Ping Time
- Output Power Status
- No. of resets recorded
- Minutes since last two resets
- Timing indicator (seconds)
Here's a couple pics of it in operation:
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of WinGPIB, WinPartsFinder/MacPartsFinder
Website: www.ianjohnston.com
YouTube: www.youtube.com/user/IanScottJohnston, Twitter(X): https://twitter.com/IanSJohnston, Github: https://github.com/Ian-Johnston?tab=repositories
« Reply #3 on: August 28, 2013, 11:40:17 am »
Hi Ian,
That's exactly what I am looking for, any rough guestimate on the cost ?
Many thanks
Alan
Online IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #4 on: August 28, 2013, 12:33:10 pm »
Hi Ian,
Many thanks
Alan
No idea.....I just made it from bits n pieces......but it can't be expensive.....it's just an Arduino with an ethernet shield & LCD, and a few other bits n bobs.
The BOM is on my webpage.....as is the Arduino code, wiring etc.
Ian.
« Last Edit: August 28, 2013, 12:35:26 pm by IanJ »
Offline Ziltoid
« Reply #5 on: August 28, 2013, 03:35:32 pm »
if your router supports openwrt or ddwrt try those. Before doing this with the arduino like Ian i would consider buying a router which supports one of those (TP-Link 1043) the cost would be i think roughly the same.
Online tszaboo
« Reply #6 on: August 28, 2013, 07:02:23 pm »
If your PC  has a parallel port, you can just connect it to a relay, with a simple transistor/FET relay driver circuit, and a cheap 12V power supply. After that it is just programming of something like 5 lines of code in batch. If the computer doesn't have parallel port, buy an USB paralel for 3 dollars.
