"IDC" just means "Insulation Displacement Connector", so any connector that punches through the insulation on the wire to make contact with the conductor is IDC.
There are a few variations in the connector keying style, some are more or less standard some of them may be special order or only made by a few manufacturers. Your best bet may be to look through a few catalogs for 100mil IDC ribbon connectors and see if you can find one that matches. Take a good look at the mating headers, since those are what you need to match. You may even find that the header has snap-in keying gizmos that can be removed to accommodate different connectors if you can't find a direct match.
