Author Topic: Identify if its a GDT or TVS  (Read 7609 times)
Offline joeqsmithTopic starter
Re: Identify if its a GDT or TVS
« Reply #50 on: July 22, 2018, 05:20:17 pm »
Glows like a GDT, arcs like a GDT, clamps very slow like a GDT..  Did finally get it to come apart.
https://youtu.be/0thOfk4I3qs?t=2278
« Reply #51 on: August 05, 2018, 10:45:32 pm »
I did write the person who commented on the YT video about it being a TVS.  Basically, I am looking for a suggested part number.   I have no doubts that a TVS could be found in this type of package but they do appear rare.  Not something I would expect to see in a commercial grade modem when plastic packages are widely available.
Online wraper
  • Country: lv
« Reply #52 on: August 08, 2018, 10:13:17 am »
TVS/zener at least do come in this package. Find at least one GDT part number that comes in such package as well.
Offline floobydust
« Reply #53 on: August 08, 2018, 07:50:12 pm »
I don't see a need for glass-packaged TVS as there is no gas envelope, like in a GDT.
Hermetic-packaged TVS are MIL spec. by Sensitron.
Online wraper
  • Country: lv
« Reply #54 on: August 09, 2018, 07:51:51 am »
Then why tons of diodes and zener diodes come in glass package?
Offline floobydust
« Reply #55 on: August 09, 2018, 07:21:17 pm »
Small switching diodes in glass hermetically-sealed packages are widely available, like DO-35, DO-41, MELF etc. I don't remember ever seeing TVS in glass packages.
I think the difficulty is to gas-fill these with say, neon to make a GDT. Or to make these larger for more power handling, for a big die (TVS) or electrodes (GDT).
joeqsmith's part, might have been:
Mitsubishi DA53
Ruilon china RL501 series 0.5kA 2mm dia. x 4mm.
« Reply #56 on: August 10, 2018, 02:13:32 pm »
Mitsubishi DA53
They are both axial, not a MELF.   Rare parts in a commercial product would make no sense at all.
Offline floobydust
« Reply #57 on: August 10, 2018, 10:02:27 pm »
It makes sense as there is no impulse standard for cable modems that I know of. What size GDT is suitable?
GDT's meet Telecom and Mains standards such as UL1449, UL497B, FCC Part 68 etc. so they are sized large.
A tiny GDT is off the radar and has no approvals, maybe a 0.5-1kA rating.
RLM501 MELF 0.5kA 2.1mm dia.
RLM102 MELF 1kA 2.8mm dia.
« Reply #58 on: August 10, 2018, 11:03:07 pm »
Yes, GDTs in a MELF package seem common.  I have not heard back from the person who posted on the YT video.  Waiting to see this glass MELF TVS they feel would go into a cheap modem.
Offline floobydust
« Reply #59 on: August 11, 2018, 03:27:15 pm »
First time to see small GDT; in Sanwa PM300 DMM? https://www.eevblog.com/forum/testgear/aneng-302-pocket-meter-by-voltlog/msg1737086/#msg1737086
In your testing, I wasn't sure if it (small GDT) could handle a Cat. III impulse.
« Reply #60 on: August 12, 2018, 03:49:37 pm »
The question mark does not appear  to follow a question.  I have never shown a category III impulse and have no way to create it.  Someone had made a similar comment about my tests damaging MOVs.   Perhaps you do not have an understanding how most of the meters I have looked at are designed.  I suggest reading post #2411
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/2400/
Sounds like Wraper is not having any luck finding a TVS that they feel would have been a replacement.  I'm not surprised as it seems it would be a special part.   Looking at the YT metrics, it did get a DV from someone in Latvia.   :-DD :-DD   Perhaps someone was upset that I was showing too much data.
Offline floobydust
« Reply #61 on: August 12, 2018, 08:22:19 pm »
It's many questions that little GDT raises, RIP. I understand multimeter protection circuits and 61010 well enough to get equipment designs certified.
The Sanwa PM300 using a slightly larger GDT with no MOV's, "The world's only CAT IV IEC61010 rated true pocket sized multimeter"
Seems strange a little GDT can pull it off, no MOV's required? Zotek and ANENG jump on board.
You and I know the let-through/follow-through current would be a catastrophe in this crappy scheme.
Looking at the PM300 approvals test report it appears fake- 61010 ESD tested to 4kV, but no mains transient testing. The PM300 product manual states that wonderful term "designed to" which is not certified to...
You think a little GDT can achieve multimeter 61010 approvals?  :popcorn:
