Author Topic: Identifying a IC  (Read 1415 times)
Offline Supreme920Topic starter
  • Country: no
Identifying a IC
« on: November 18, 2025, 10:50:47 am »
good day everyone,
Long time viewer of the EEV channel, but never joined the forum. Today is the day :)
I have spent the last our trying to identify a IC chip on a cheap PIR motion detector, but no luck so far. The goal is to extend the timer, default time is between 10 seconds and 15 minutes. I want to increase it to approx 3 or 4 hours. I thought it might be a simple RC circuit, and I would just add a capacitor to extend the time. However it seems its controlled by an IC. The marking on the IC in only 12-9 in a SO14 package. Not so help full marking...
The middle pin from the time potential resistor is connected to pin 11 (the via is below the IC)
Pictures are here:
https://mschinkelshoek.quickconnect.to/mo/sharing/xgUK8QVMK
If more information is needed let me know!
Your help is much appreciated, mainly by our rabbits, who will get a infrared lamp for heating in the winter time, triggered by their movement :)
Online ledtester
Re: Identifying a IC
« Reply #1 on: November 18, 2025, 11:57:16 am »
A simple solution is to have the PIR sensor's relay trigger a relay timer like this one:
https://www.amazon.com/DROK-Controller-Delay-off-0-01s-9999mins-Switching/dp/B07DFT2WDS/
« Last Edit: November 18, 2025, 12:12:07 pm by ledtester »
The following users thanked this post: Supreme920
  • Country: no
« Reply #2 on: November 18, 2025, 12:14:11 pm »
Yes that is good alternative, however, its outside, and i wanted to keep it as simple and robust as possible, therefor I was hoping to use IP44 rated product. Your solution would mean an extra 5V supply as well.
I do appreciate your thinking outside the box solution! And i keep it as a backup plan!
Online ledtester
« Reply #3 on: November 18, 2025, 12:41:55 pm »
Instead of changing the capacitor you can try swapping out the resistor (i.e. the potentiometer) responsible for setting the time.
15 mins to 4 hours is a factor of 16. So if the timer pot is a 10K maybe change it for a 200K pot.
Long RC timers are not always that reliable but it might work.
Be careful in there - you're working with a mains powered circuit!
« Last Edit: November 18, 2025, 12:44:04 pm by ledtester »
  • Country: no
« Reply #4 on: November 18, 2025, 04:14:45 pm »
Thanks for the suggestion, but I am wondering if it is an RC circuit, or if the resistor is just an input for the setting in the IC. that is why I was hoping to find the datasheet.
But I will test it out, take out the pot and add a bigger resistor.
Thank you for your input.
Online NE666
« Reply #5 on: November 18, 2025, 05:36:48 pm »
You might consider a mains powered timed relay variant, and mount in in a suitably IP rated exterior DIN enclosure. This is how I hold my garden lighting on for an hour after sunset, once the supply is activated by a dusk 'till dawn time switch.
https://www.amazon.co.uk/dp/B07WFM671V
Online moffy
« Reply #6 on: November 19, 2025, 02:47:53 am »
If you have a scope you can look for a clock signal, and if you find one, if by varying any capacitors nearby you can modify the frequency.
Online ledtester
« Reply #7 on: November 19, 2025, 11:49:06 am »
It looks like it powered by a capacitive dropper supply... (see attachment).
The following users thanked this post: moffy
Online moffy
« Reply #8 on: November 19, 2025, 09:08:23 pm »
Might be dangerous hooking a scope up if powered from mains, so best to use a bench supply for the investigation. Or are you implying that it counts mains cycles for timing? Not sure what you mean, it still needs a clock if it is some sort of logic/micro, which it looks like, could be internal or external clock, if external then modifying it might change the timing.
P.S. The big blue cap looks very much like a capacitive supply cap. :)
« Last Edit: November 19, 2025, 09:11:21 pm by moffy »
Online ledtester
« Reply #9 on: November 20, 2025, 12:15:33 am »
I think it is dangerous to have a beginner use an oscilloscope on a capacitive dropper powered circuit.
Online moffy
« Reply #10 on: November 20, 2025, 01:11:33 am »
That is a good point, I sometimes assume the target audience is experienced.
Offline m k
« Reply #11 on: November 20, 2025, 05:13:10 pm »
Make a piggypack extended timer circuit.
Or replace the whole original one.
How's the time adjusted?
It can still be RC, 150k pot and one elco.
