Author Topic: Identifying some CCCP Transformers  (Read 2355 times)
Offline induzerTopic starter
  • former employed in the renewable energy branch
    • Laborlogbuch
« on: September 16, 2018, 05:32:34 pm »
Hi there,
I just bought a display unit with nixies for a short wave transceiver set for telex recon from formerly CCCP.
Before I take it apart, using it as desk clock, I record the schematics. The unit seems to be rarely documented.
All is recorded so far, but the power supply. It uses self oscillating circuits for its 2 power rails.
Sadly the 2 transformes are perfectly potted, and I haven't a clue how the inductors are arranged inside.
... Someone an idea ?
Cheers,
induzer
Online SeanB
Re: Identifying some CCCP Transformers
« Reply #1 on: September 16, 2018, 06:26:51 pm »
I assume the 2 transformers are not the same part, so pins 1 and 2 are the primary winding on the top one. Pins 6 and 7 are the feedback winding, and pin 6 is the other side of the feedback  winding for regulation. Pin 7 is a common on the secondary, and it is part tapped at pin 8 for voltage sense and pin 3 is the high voltage winding.
Bottom one pins 1 and 2 are primary again, pin 5 is the common for the secondaries, and feedback is from pins 4 and 3. Secondary is pin 5 and 6, with voltage there used to regulate the oscillation on the transformer.
Bottom one i guess supplies 5V at around 1A, top is 160v at 10mA or so.
Online exe
  • self-educated hobbyist
« Reply #2 on: September 17, 2018, 06:34:32 am »
Do you have photos of these transformers? There should be some marking...
    • Laborlogbuch
« Reply #3 on: September 17, 2018, 09:30:47 pm »
...some photos
Online exe
« Reply #4 on: September 17, 2018, 10:24:37 pm »
I didn't find anything about the transformers. Can you please show photo of front panel with logo and model name?
    • Laborlogbuch
« Reply #5 on: September 17, 2018, 10:43:30 pm »
Its the third module from the top.
The type is R1250 M/B
Manufactured by ML - Mechanikai Laboratórium, Budapest.
http://militaermuseum-anhalt.de/images/stories/SpezAkltechnik/Steckbriefe/R1250/r1250-001.jpg
« Last Edit: September 17, 2018, 10:47:00 pm by induzer »
Offline Bud
« Reply #6 on: September 17, 2018, 11:47:59 pm »
Holy cow  :o, did you get the whole station or just the nixie module?
    • Laborlogbuch
« Reply #7 on: September 18, 2018, 06:27:28 pm »
 ;D ... regretfully only the nixie module  :(
Offline Frank65
« Reply #8 on: October 04, 2025, 12:25:53 pm »
Hallo,
ich habe in deinem Blog von 2019 Nixiclock - greeting from UdSSR gelesen, dass du dich mit dem Nixon Einschub aus dem Empfangsgestell R-1250M-1 beschäftigt hast. Ich suche für diesen Einschub dringend die Schaltungsunterlagen.
Kannst du mir helfen?
Vy73 de Frank
