Author Topic: IEC 61000-4-5 Surge immunity test  (Read 53874 times)
Offline lewis
  • Nullius in verba
Re: IEC 61000-4-5 Surge immunity test
« Reply #25 on: July 09, 2014, 03:14:31 pm »
I agree with Andy C, ISO 7637-2 is the applicable standard for automotive conducted susceptibility in supply lines. Pulse 5 (load dump pulse) from 7637 is now referenced in ISO 16750-2. The most onerous load dump pulse is 174V, 1R, 350ms for a 24V nominal supply. That's a pain to comply with, almost all standard TVSes will die easily. More info here: http://www.radiocad.co.uk/files/1413/6921/7114/LoadDumpPaper-final.pdf
Buy a copy of these standards. EN/IEC 61000-4-5 is probably only applicable to mains voltage transients, or transients on communication or signal ports, and should not be necessary for power inputs in your application. Triple check whether you really need to comply with it.
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline Mad IDTopic starter
« Reply #26 on: July 09, 2014, 03:32:07 pm »
Hi. At the moment we need the CE declaration. I undestand there are other tests but once again, CE mark (Declaration of conformity) is what we are after at the moment.
You have all been very helpful, thank you very much!
Online AndyC_772
« Reply #27 on: July 09, 2014, 04:04:56 pm »
Just to be clear: I (and, it would appear, we) believe that ISO 7637-2 is the applicable test which your equipment would need to pass in order to qualify for a CE mark, and not necessarily IEC 61000-4-5.
Sometimes, determining which tests are applicable to a product can be as difficult as engineering the product to pass them :(
« Reply #28 on: July 10, 2014, 01:47:57 pm »
I will look into it.
Thanks.
Offline qno
« Reply #29 on: July 10, 2014, 04:05:47 pm »
I have passed the test by placing a P Mosfet in front of a 7805 that switches off when input voltage is > 35V.
The MOSFET has to be able to withstand 200V.
You fall into the category that will reset when the puls is aplied but resumes normal operation when normal power is restored.
If you define this behavior in advance you will pass.
Please set your country.
« Last Edit: July 10, 2014, 04:10:55 pm by qno »
Why spend money I don't have on things I don't need to impress people I don't like?
Offline Circuitous
    • Corgi-Tronics
« Reply #30 on: July 10, 2014, 04:25:08 pm »
qno that sounds like a neat approach, do you have an example schematic of that?
Offline qno
« Reply #31 on: July 13, 2014, 07:37:51 pm »
I can not give you the exact circuit but this datasheet gave me the idea.
http://www.maximintegrated.com/en/app-notes/index.mvp/id/4081
Here is where it is based on.
Offline Circuitous
    • Corgi-Tronics
« Reply #32 on: July 14, 2014, 12:10:04 am »
Perfect!  That looks like just what I need for an upcoming project.  Thanks!
Offline AndersJ
« Reply #33 on: February 23, 2016, 03:05:36 am »
61000-4-5 says that surge transients are injected between ground and signal lines.
"Ground" in this case means the device chassis, protective ground.
"Signal lines" in my case, and for many other devices are signal ground and the signal itself,
such as 5V digital inputs, 0-10V analog inputs, or an industrial 24V dc signal input, or similar outputs.
Often, as in a PC, and many lab instruments,
signal ground is galvanically connected to chassis/PG.
In these cases,
are surges applied between ground and signal ground?
This implies injecting the surge on a short circuit.
Is this how it is done?
« Last Edit: February 23, 2016, 03:43:07 am by AndersJ »
"It should work"
R.N.Naidoo
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #34 on: February 23, 2016, 08:20:58 pm »
I'd have to look at the precise wording of the standard, but I don't see that there would be any harm of it.  The surge generator is designed for open, resistive and short loads.  As is true of any other pin, it should simply not do anything. Right? ;)
Seven Transistor Labs, LLC
Offline HackedFridgeMagnet
« Reply #35 on: February 23, 2016, 10:07:34 pm »
Your ground wire will probably come into the DUT from a different wire than the signal ground.
Every wire has an inductance so what is a short circuit at dc may not be for a surge.
Surges are generally modelled as a current source. eg. 50kA 10us up and 350 us down.
The voltages that are generated by the surge through the inductances may cause arcing between different parts of the DUT.
This is one of the things you would be testing for.
Also not all signals are unbalanced with one side grounded.
So put the surge across each signal wire to the ground lead of the DUT.
To create the surge use something like Mikes electric stuff's destructor or whatever he calls it. He has a video where he tests the circuit breaker.
A capacitor bank charged up with high voltage. Obviously very dangerous!
Use an isolated (wireless?) remote to trigger a thryristor to send the surge.
You can measure the surge with a current transformer that attaches to a scope.
Offline T3sl4co1l
« Reply #36 on: February 24, 2016, 09:26:33 am »
Er, well, not just ANY bare capacitor, or random wiring, and certainly not a bank of defibrillator capacitors at full charge!!
IEC 61000-4-5 defines a maximum Class 4 of 4kV (into 2 ohms, 2kA) surge.  The time constant into 2 ohms is about 28us (it's not really a time constant because an RLC circuit is used), so about 14uF is needed.
To get the open-circuit waveform, some series inductance and parallel resistance is needed.  Resistance might be around 3 ohm, which means the 1.2us rise time (for this condition) needs around 2uH.
To get the short-circuit waveform, more series inductance is needed (though not much more), a total of double I guess.  The extra parallel resistance means more capacitance will be needed, maybe 24uF.
In the two conditions, sqrt(L/C) is much less than the ESR of the loop thus formed, so it should have no undershoot (the standard allows for 30% phase reversal), and no need for diodes and stuff.  A contactor is probably okay for switching the surge (it's over before the contacts can bounce open again), or thyristors of not too extreme ratings (but do turn them on hard!).
Offline jeroen74
« Reply #37 on: February 24, 2016, 12:21:55 pm »
A few years ago I did this very test on a mains-fed lamp controller widget supposed to be mounted in a lantern pole, but up to 8KV. Naturally things got quite explosive once that poor MOV decided it was time to give up around the 25th pulse.
The scope indicated about 1 megawatt of dissipation for a microsecond.
Offline zare.zz
  • Country: ir
« Reply #38 on: June 15, 2021, 05:55:05 am »
how can I find a appropriate TVs diode for pass a IEC61000-4-5 CLASS3(2KV)?
Offline jonpaul
    • IEEE Spectrum
« Reply #39 on: June 15, 2021, 06:46:50 am »
Hello: Are you sure that IEC 61000-4-5 Surge immunity test is required for your product? Normally that is for mains connected PSU, not low voltage.
Which surge tester was used?
Generally we avoid MOVs as they are very 'soft" and wear out. Sometimes they catch fire after an overload.
Load dump protection for 28V systems were very large die Zeners like Motorola MR2525.
Vishay   TransZorb diode, https://www.vishay.com/diodes/protection-tvs-esd/
Bon chance,
Jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
