Doesn't it need more copper for a coil without an iron/ferrite core?
What did you use a 5mh coil for?
Does the magnetic field matter if it is left in the ferrite core from the woofer thought of trying to wind one. And if it dose any good tips on how to demagnetize it, tried heating a ferrite core to 480C but it cracked.
Oh, I finally parsed this-- you have the ferrite
magnet from a woofer (large speaker), and
you thought about trying to make an inductor with it.
This project has all the red flags:
- Lack of information (poorly documented system, unfamiliarity with SMPS component selection/design)
- Beginner project / massive power level
- Looking for impossibly cheap solutions without knowing whether they could even work
I may be severely misinterpreting the poor grammar here -- English sucks enough for native speakers as it is -- but it happens that it conveys a message of carelessness.
Case in point, a ferrite toroid is the wrong thing. Ungapped ferrite saturates at low currents -- maybe ten amperes in the size you require.
A magnet is even worse: it has maximum hysteresis loss and no permeability. It's completely the wrong kind of ferrite to use here.
The most likely material is powdered iron, which you will still spend a few hundred bucks on for something of this size starting from new commercial parts.
It paints a picture of, you've purchased this product, and some salvaged parts, in the hopes of throwing together a cheap system, and now you've hit a snag because you didn't think far enough ahead to even know what
basic components a buck converter requires (i.e. input cap, choke, output cap), and have neglected to budget for it in any way shape or form, purely assuming that you'll stumble into a solution along the way, as you've seemed to with every other part so far.
Without seeing any build photos and schematics, I will go out on a limb and guess that this will be a fine way to end up electrocuting yourself, or burning down the house and potentially the neighbors too. At the very least, significant property damage is a possibility, from the rather large solar panels (or other sources), or the EV [battery?], to any surrounding buildings, or loss of life, and, I don't know maybe negligence charges related to those or something. No insurance company will cover such a hack job, you're on the hook for any and all destruction resulting from this thing.
I strongly urge other posters here to heed the same warning, and provide no further assistance until a safe assessment can be made.Tim
