Hello Forum
we do have some troubles with understanding whats happens thermal in an DCDC-Konverter running with some power (25kW).
So here are some details and maybe someone can help us understanding a little bit:
The Primaryside of the converter (H-Bridge) switches something around +/-60A into the transformer with a short deadtime when under full power.
The IGBTs should handle this without any problem if cooling is well done. Our watercooler (surface 1mm nearby the IGBTs) goes up to 40°C so this should be fine and well within the limits required for good cooling. CE-Sat ist something around 2,2V (measured) so powerlosses (per IGBT) are below 70W, with free-wheeling-diodes and snubber-stuff we calculated 400W Ptot...
The system is running fine some time but:
what we see is at full power that part of the IGBTs get really hot, please see FLIR-Image, SP5 (126°C). Other parts of the housing are fine (SP1, 3, 4) and the cooler beside is (a little bit to low) shown with 26°C
Flir is calibrated to the IGBT-housing (not to the cooler), so temperatures are mor or less within +/-1°C.
Birdge_lowside_xxx shows the thermal IGBT with Rogowski mounted. The Rogowski was moved a little bit out of the line of sight in the FLIR-image. red and black wire are used for measuring CE-Voltage.
We assume that these hotspots are the area of the bondingwires and not the silicon-temperature. But we dont know exactly and what makes us wonder is - it`s only 60A, the device (IXYK140N90C3) is specified with 140A @ 110°C and even terminal current limit is specified with 160A....
Electrical isolation to the cooler is done with ceramic-pads with 25W/mK (meter-Kelvin, not milli-Kelvin) or 0,08°C/W.
So our question is - does someone have an other explanation how this high temperature is generated and - any ideas how this high temerature do age the IGBTs housing?
Thanks for reading and maybe some usefull ideas.
regards
Michael
