Today while driving to work my car's engine suddenly went (as though a switch was flicked) from purring like a kitten to running as rough as guts. Rang work to inform and book the day off against leave and did a U-turn for the transmission shop. It was overdue for a transmission service and they aren't open Saturdays. The transmission had nothing to do with the problem, but since I was now having a non-public holiday weekday off I figured I'd get that out of the way.
After the trans service I barely made it home though, engine's ill running progressing towards being terminal and finally stalling when pulling into my driveway. It was quite a while since I changed the ignition leads, dizzy cap and rotor (actually overdue for renewal), so I bought what I needed while the car was in the transmission shop and renewed all of that after limping home. Engine still idled like cwap, barely starting. By this time other checks ruled out any cause other than ignition, so I swapped out the next obvious thing (the ignition coil) with another known to be good that I had handy.
There was no change, ruling out the coil, and all I am currently getting whilst cranking is a wimpy orange spark barely strong enough to bridge the gap of a spark plug.
It was then time to break out the Rigol. My engine is equipped with a Bosch HEI electronic distributor and matching HEC716 ignition coil. The potted "HEI" module (mounted withing the distributor housing) has failed on me before and it looks like it has gone again. The first time it just died outright while I was driving in the right most lane of four in freeway-like traffic, in low 40 degrees Celsius heat. Handy that; and so far the only time in the 14 years I've been driving the car that I need to call a tow truck. That was an easy diagnosis, because the coil (-) just remained at the same potential as the (+) terminal. The switching transistor inside the potted module had died open circuit.
Attached are scope traces of the potential at the (-) terminal while cranking the engine. I've got ~30mS of dwell which looks OK for the first 5mS only, followed by ~3mS of wimpy burn. Bosch rate the HEC716 coil primary current at 6A peak and the DCR at 0.41 ohms. I'm pretty sure the inductance is in the vicinity of 8 to 10 mH.
The first 5mS of dwell looks OK. With 8-10mH of inductance it will take approx that long for the coil current to reach the specified 6A, at which point the HEI module should start current limiting. Current limiting post ~5mS is where things appear to be going pear-shaped. 6A at 0.41 ohms DCR = ~2.5V, so post 5mS the (-) terminal potential should rise to the battery voltage minus 2.5V and remain there until the end of the dwell period, and this is what happens initially, but then things begin to look seriously abnormal.
The current limit is oscillating all over the place, with a mean potential across the coil primary of approximately half the battery voltage, which computes to an average approximate primary coil current (given the 0.41 ohm DCR) approaching 15A.
So here is my question. Are these high-energy-ignition-compatible coils particularly susceptible to saturation if driven beyond their peak primary current rating? The loss of inductance is the only mechanism I can think of ATM that is causing that massive (abnormal) coil primary current to give me the woefully inadequate spark that I am getting.
