Author Topic: I'm developing a 1000W electronic load. 80V, 50A  (Read 4296 times)
Offline MOSsFETTopic starter
Re: I'm developing a 1000W electronic load. 80V, 50A
« Reply #25 on: June 12, 2026, 11:49:53 am »
I made this short video to show the 1000W electronic load load operating and how the web app is used to control it: https://youtu.be/gFIf8tUbkxg
I'm actively developing the load so please let me know if you have any suggestions for the UI or other features I should add to it.
Cheers
Offline andrewtaylor
« Reply #26 on: June 12, 2026, 05:56:52 pm »
Looks very nice, so congratulations to your succesful work!
The following users thanked this post: MOSsFET
Offline Psi
« Reply #27 on: June 26, 2026, 10:57:40 am »
Looks great,
I would probably have put a simple 7SEG/LED/OLED/LCD display on the box, just a simple display to show the current A and V, maybe W too, so you can a see what's happening at a quick glance from the other side of the room without needing to use the tablet or get out your phone.  Not any configuration/menu/touch stuff, you have the app for that. just A, V and maybe W and internal temp if you want to get fancy.  Some big 7SEGs would be cool but maybe that's just me.
Maybe shorten those bolts on the terminals so a metal object like a screwdriver that rolls under it cant short across the terminals
« Last Edit: June 26, 2026, 11:20:53 am by Psi »
Offline Phil1977
« Reply #28 on: June 26, 2026, 12:16:42 pm »
Nice to see that loads that do not only dissipate in the FET are being used.
I sometimes use such a 1500W-Step up module together with four 36V/400W halogen bulbs for that purpose. I've never build a control loop around it, so I need to use a screwdriver to set the desired load power.
For testing batteries it would be perfect to have a buck-boost-converter that controls *input* current or power and just dumps everything in a halogen bulb load until a minimum input voltage is reached. Does anyone know of such a device or has already DIYed it?
Offline max.wwwang
  • Country: cn
« Reply #29 on: June 28, 2026, 04:53:04 am »
Watched the vid. Very interesting, nice job! Particularly the user interface. It’ll be great if some detail of the design can be shared, both hardware and software.
Neutral | grounded
« Reply #30 on: June 29, 2026, 10:29:10 am »
There are more details of the design including a PDF of the schematic in my Hackaday project: https://hackaday.io/project/205930-smart-1000w-electronic-load-without-a-heatsink
The following users thanked this post: max.wwwang, Phil1977
