Author Topic: Impedance Analyzer Build and Experiments  (Read 157440 times)
0 Members and 27 Guests are viewing this topic.
Offline jaxbirdTopic starter
Re: Impedance Analyzer Build and Experiments
« Reply #150 on: March 13, 2015, 12:42:36 pm »
the $99 is for an US student only ... otherwise it's $279
You can get them from MicrochipDirect for much less than that without being a student, plus I believe they run a campaign with free shipping this month. I'm sure I got an email somewhere, and that reminds me, I should order some stuff :)
Just don't get it because of this project, as I have no idea when I'm confident enough in the design and software to share.
Edit: to clarify, Microchip sells these for ~$220/each no matter who you are :)
« Last Edit: March 13, 2015, 03:17:46 pm by jaxbird »
Analog Discovery Projects: http://www.thestuffmade.com
Youtube random project videos: https://www.youtube.com/user/TheStuffMade
« Reply #151 on: March 13, 2015, 01:07:08 pm »
New board ready:
« Reply #152 on: March 13, 2015, 01:41:09 pm »
Testing the extremes of the instrument. I've found this little 22nF Wima is very good to test the extremes in both frequency, sensitivity and linearity.
« Reply #153 on: March 13, 2015, 01:46:24 pm »
Measurement of 22nF from 1Hz to 20MHz, 10M to 10m range:
Much better than I had expected, I was expecting upper limit to be about 200-500k, but 5M+ is indeed possible.
Offline AlfBaz
« Reply #154 on: March 13, 2015, 03:59:03 pm »
I'm curious, how long does it typically take to do a complete frequency sweep and analysis from say, 1Hz to 10Mhz and what is the minimum number of samples you would need for that range?
« Last Edit: March 13, 2015, 04:01:17 pm by AlfBaz »
« Reply #155 on: March 13, 2015, 11:50:12 pm »
I haven't actually timed a full scan, the time depends on how low in frequency you want to go, anything below 10Hz is pretty slow. I always use the full 2x8k sample memory, but I do have some optimization, below 10 Hz I only sample 2 full waves, so that is 2 seconds+ per sample @ 1Hz, between 10 and 100Hz I sample 4 waves, 100 to 1kHz is 8 waves and above that 16 waves for the DFT. Retrieving the sample data and computing DFT plus various calculations for each sample is pretty quick,
For e.g. a capacitor measurement I rarely use anything below 100Hz, unless it's a large capacitor used in rectification.
In most cases 200 samples across the frequency range is enough to give a nice detailed measurement. It's what I use by default.
« Reply #156 on: November 26, 2015, 06:08:31 pm »
I've received a large number of private messages on this project while i've been away. It's always been my intention to release something at some point, whatever that means, but sometimes life happens, however I will post a video very soon explaining the functionality and I will make the design and software available free of charge, I hope my many hundreds hours of original work put into this project will be appreciated and not just copied into some shitty open source kickstarter like many before me or sold as original work on some shitty chinese site.
TLDR; I will post instruction video, schematics and software within the next week or so.
Offline dannyf
« Reply #157 on: November 26, 2015, 08:37:07 pm »
great work, jaxbird.
Likely that's where it is going.
Providing some hack-proof and visible signature in the software will help deter that.
Offline Wolfram
  • Country: no
« Reply #158 on: November 27, 2015, 10:49:21 am »
Amazing work, looking forward to finally being able to make a decent impedance analyzer.
« Reply #159 on: December 26, 2015, 06:09:08 am »
Would everyone prefer a kit available on eBay? (including pcb, essential high speed opamps, caps, shunts, cables and clips)
or just making a pcb themselves being ignorant of the essential knowledge how to achieve the best performance?
« Reply #160 on: December 26, 2015, 06:11:48 am »
Online fpliuzzi
« Reply #161 on: December 26, 2015, 06:41:46 am »
Your ebay kit idea sounds like an optimum way for a user, such as myself, to more easily mirror the quality measurement results that you have produced using your unit. I would certainly be interested in a kit containing the items you've listed above.
« Reply #162 on: February 03, 2016, 06:15:14 pm »
Small teaser:
I think I do need to add at least a little bit of input protection, perhaps a handful of BAV99 and some resistors.
Offline LaserSteve
« Reply #163 on: February 03, 2016, 11:14:43 pm »
Considering your software looks an order of magnitude or two  better then the AD Demo board's included code, I'm highly interested. I work at a university and this chip would be the cat's meow for one of our small projects.  I have the demo board, and while the board is excellent. I have my doubts that the contract programmer knew what he was working on.
Steve
"I calculated the stored energy, and it is enough to play the Dance / DJ Extended edition of "Baby Shark" in all 100 headsets for the production floor team simultaneously over 100,000 Times."
Well, I had to explain it to my boss, somehow.  He's an Accountant,  not a PHB.
Online fpliuzzi
« Reply #164 on: February 05, 2016, 01:52:39 am »
That's some teaser. Your Impedance analyzer software is pretty remarkable. You've really included quite a bit of flexibility into its operation.
« Reply #165 on: February 15, 2016, 09:23:24 am »
Steve
Well, I'll release it for free once I have everything ready, just need to find the time to get everything together. I do contract work, but I doubt you'd find my rates reasonable :) .. especially if looking for a bargain. I mostly deal with very large corps where I really do need to factor in a lot of overhead, insurance, travel, meetings etc.
Thanks, I did put a lot of effort into this project. I do think it's got a lot of potential, but sure, only a somewhat narrow audience.
Offline voltsandjolts
« Reply #166 on: March 10, 2016, 08:41:43 pm »
This is fantastic jaxbird. Well done.  :-+
Dave needs to do a review on this puppy when its complete, "young players" could learn a lot from this tool. And, ahem, some older players like me.
Offline rx8pilot
« Reply #167 on: March 11, 2016, 09:51:44 pm »
This is a cool project. Wish I could have this right now.
Offline quarks
« Reply #168 on: March 16, 2016, 03:24:16 am »
 great project :-+
« Reply #169 on: May 12, 2016, 12:57:14 pm »
Thanks, I really find this tool has been very helpful in getting a better understanding of the relationship of many impedance related parameters, especially how to determine the quality of a capacitor, inductor etc.
I just wanted to make a usable ESR meter, but I kinda got caught up it in, and then The Electrician showed off his beautiful impedance analyzer, then that became my new benchmark, so I guess it's an unhealthy obsession coming to an end really. I'm proud of the end result though, I achieved or exceeded all the parameters I had for the project.
I have posted a video of the plug in board for those intersted.
« Reply #170 on: May 12, 2016, 12:59:48 pm »
New video, describing the plugin board and the design decisions involved:
The following users thanked this post: fpliuzzi, Ivan7enych
Online fpliuzzi
« Reply #171 on: May 13, 2016, 04:47:21 pm »
I like the addition of the option to install SMA connectors on the input side of the PCB. It's always nice to be able to add an assortment of test jigs to a measurement device if needed. Nice touch.
Offline ruairi
« Reply #172 on: May 23, 2016, 03:32:49 am »
Fascinating project, thanks for the great video.
« Reply #173 on: May 23, 2016, 01:58:23 pm »
I will probably make a kit available, I think it will be around $50 including all parts (except the Analog discovery itself), it will work with both version 1 and 2 of the Analog Discovery and include everything including reasonable kelvin clips. I hope that is reasonable, I think it will cover the cost of all the parts with shipping from various vendors etc. It should not be a problem to solder the kit together for anyone interested, it's all 0805 or larger parts and so8/16 parts.
Shipping will be an additional $10 world wide. I will only be able to handle small quantities, but I think not a problem as the interest in this should be quite narrow. Anyway, the software if free for anyone who'd rather build their own, just keep in mind this is a hobby project so while I'll do my best to fix any bugs it might take a bit of time for me to respond to any bug reports.
I'll post another video on general usage and calibration of the device for best performance.
I'm sending one to Dave for evaluation, will be interesting to hear his opinion on the project.
Offline ruairi
« Reply #174 on: May 23, 2016, 05:40:43 pm »
That sounds great, I'm in for a kit whenever they are ready.
Thank you,
Ruairi
