Sorry, but don't have a JEDEC or another spec source, care to provide one? Otherwise I'll keep using Wiki and various known manufactures such as On Semi, Vishay, Diodes, and so on.
Reverse Recovery Time
Well we've compared apples to apples and according to other 1N4148W specs (Vishay, Diodes, Semtech, MCC, On Semi, and so on) the answer is the Jingdao 1N4148W does not match or even approach the capacitance and reverse recovery (maybe more parameters, but we didn't check) specs!! Exactly why IMO this should not be considered a 1N4148W.
Think we've wasted enough of our and others time and BW on this subject. If you chose to view the 1N4148 as a generic jelly bean diode without much regard to capacitance and reverse recovery parameters, go ahead and do so
Anything else is not JEDEC but just arbitrary stuff the manufacturers slap on to . so that W means exactly nothing ... where JEDEC is concerned. You'd expect a 1N4148W from abc to be the same as a 1N4148W from xyz , but that is not necessarily the case. And since capacitance is not part of the RDF ...
This is all we need to know about the value your responses, and what your true knowledge base is!!
1N41418
You're being ridiculous!
You are turning other people/engineers, into simple on/off, black and white 'boxes'. That are either 100% correct/right/accurate all the time, or potentially/fully wrong. People/engineers etc, are NOT as simple as that.
The person who sweeps the floor of someones labs, might say a particular component is WRONG, because it looks a funny colour. They may have absolutely no knowledge of electronics. But that DOESN'T mean that what they say is wrong. Maybe (probably not), that component is WRONG, it could be the case.
Analogy/example, let me poke fun at you:1N41418
You can't even 'spell' 1N4148, so I'm going to ignore all future responses you make. As you can't even get 1N4148 correct!. (Joke, for dramatic effect).
Before we started this post we expected a 1N4148 of any flavor to have <4pF capacitance and <4ns reverse recovery based upon many decades of use, despite all the prior discussion and arguing this hasn't changed, as we still consider a 1N4148 to fit within 4pF and 4ns, and frankly that's all that matters here at the Labs!!
Ridiculous? Don't think so!! Not turning anyone into anything, we'll let them do that by themselves, yourself included
Yes we misspell often, certainly not the first nor the last time. However, we don't spew out a bunch of misinformation as has been shown, and frankly don't have the time nor patience for this kind of BS.
So obviously you are completely contradicting yourself here!!!
So obviously you are completely contradicting yourself here!!!Letter suffixes in general mean a tightening of the spec. I gave you the list as per RS-370-B. It stops at K for revisions. there are some other letters that have special meaning.QuoteThis is all we need to know about the value your responses, and what your true knowledge base is!!
way to go Mr "wikipedia 1n4148". i'm out.
Um?
I am manifestly aware of, and quite fully support the fact that, I am 100% potentially wrong, all of the time. Like, there was any other option? Get real.
But herein lies a microcosm of this thread... there's always going to be those who are wronger than most. Learn to spot them, and ignore them.
almost all sources indicate a max C and Tr, only Jingdao uses typical for both.
Most of my later career involved SOTA IC design, a mistake here could easily cost well over $5M, since the mask sets alone cost $5~20M and that was a decade ago, today likely 10X as much. You quickly learn who to trust with critical design tasks, and since many times new folks to the group get "assigned" by management you quickly need to access their individual skill and knowledge level, so a skill learned by necessity!!
Edit: Should mention the good that came out of all this "discussion" was the exceptionally low C of certain 1N4148Ws, I mean a Cj of ~0.66pF @ 0 volt bias
Well, during the course of this thread, I did a very quick (online) investigation of that manufacturer, and it seems they are very big, as regards diodes. A huge number of their range (quick look by me), easily perform at very high speed, and with very low (zero volt) capacitances.
So, I'd suspect that there is some reason, why those so called '1N4148W's, have such (relatively) poor specification. (Speculation) It could be they are 'rejects' from other diode lines, or other ways, poorly performing diode dies, became available for their 1N4148W's.
Probably we will never know. Or someone gets overly curious, and investigates the diodes further, in an attempt to identify what they really are.
Also on reflection. I DON'T feel anything like, as bad about you using Wikipedia, as a reference source, as I originally did. Although there are still some lingering doubts, and there are better, more definitive sources. At least you had a set of sources that the Wikipedia article gave. Which you were able to leaf through and nominally check out.
Sometimes, a Wikipedia article, is the ONLY available source of information. In which case you either use it, or accept not having any information at all, at least for the time being. Some new things in Electronics and Computing, is initially only mentioned in Wikipedia articles, and some (dubious) websites. Until it is officially announced, by the proper/official sources.
That is amazing! Particularly, as it is still a super cheap and available (at least BEFORE the chip shortages), component (1N4148W).
Discussions often create all sorts of new knowledge, and stuff, that was not realized before.
Interestingly, there's a MMBT7002 from a handful of small manufacturers, so it seems.
MMBT I don't know the history of, but for sure it's not JEDEC's normal numbering system.
As an electronic engineer from China, based on my experience, I suggest that when you buy discrete semiconductor devices in LCSC, choose Changjiang Electronics products, they have a longer history and should have more reliable product quality.
https://lcsc.com/product-detail/Switching-Diode_Changjiang-Electronics-Tech-CJ-1N4148W_C2099.html
If it was a Chinese make. Was it important to check if they were a recommended Chinese make or not ?
