Hi Everyone, I have a project that I am working on that is pov display. These things are the internet full but I have my own ideas. I do not want to use a battery onboard or any sort of slip ring configuration. I want to use induction power transfer. I believe this might not be the best option, but it most certainly is the option that intrigues me the most, and it is something that I have always wanted to learn more about, so I choose to implement that.
The thing I am not knowledgeable enough about is this subject, I have read up about that and I think that I might have half an idea how that works. Here are some thoughts and plans that I have. Any criticism is welcome, it probably is that all this is a bunch of nonsense that I dreamed up since I could not find an easy and clear guide, I had to piece my understanding together from various reads.
1. The first thing that came to mind was that I could determine the inductance of my primary coil and then add a capacitor in series so that the resonant frequency of this "band pass filter" matches the 50Hz that I would be getting from my wall. Sadly the 50Hz I would have from my wall socket(yes I would step it down to something like 12v) being as low as it is, would require me to put in a rather large capacitor depending on the primary coil that I could wind.
2. I could create some sort of AC-AC (or even DC-AC) circuit that would change the frequency of the signal and therefore tune that into resonance to have maximum magnetic flux in the primary coil.
Any ideas and input would be appreciated.
