I am doing a project where I have to know some of the properties in a process technology but I don't know where to find them so I hope some of you guys can help me.
I want to calculate the Q-factor of an inductor integrated in the top metal layer of a silicon chip by the dimensions (I use the paper "A physical model for planar spiral inductors on silicon" for the equations) and needs to know the following parameters:
l = overall length of spiral, w = line width, d = metal skin depth, t = metal thickness, N = number of turns, n = number of crossovers between spiral and center-tap = N - 1, tox M1-M2 = oxide thickness between spiral and centertap, tox = oxide thickness between spiral and substrate, Csub = substrate capacitance per unit area, Gsub = substrate conductance per unit area.
I have everything except for Csub and Gsub, which I don't know how to find and the paper states: "Csub and Gsub are the properties of the silicon substrate and are extracted from measured data". First of all I would like to know if anybody knows what they are for? The text says that it is "substrate capacitance per unit area" but capacitance in relation to what? And second if anybody knows where I might be able to find the values of these parameters that would be great?
I have access to the process technology documentation that my design Is based on but I can't seem to find anything in them?! Are they maybe hidden somewhere as something else?
