As you are going to drive a display simply use a pair of 4050 buffers to provide the required current. If you do not want to, and are willing to drive the LED's with 2mA per segment then arrange using a common anode display and use the device to sink current. As it is TTL compatible it can sink a lot better than source, so program the outputs in your logic table to be active low and use it that way. It is not quite proper TTL, which can do 24mA per output, but is capable of driving a single LSTTL load of 2.1mA. probably will do 5mA but not with the output voltage being a valid logic level any more but for a LED it is no worry.
