Author Topic: Interfacing mass-produced camera chips  (Read 1819 times)
Offline 741Topic starter
    • Circuit & PCB Design (small PCB quantities OK)
« on: May 16, 2018, 02:24:25 pm »
I had an enquiry about producing a customised cycling/action camera. I'd guessing '720p', not sure.
I wonder how to source/second-source the basic camera 'chips' and how to interface, also typical pricing and what standards the various chips might have in common.
It needs to loop-record to SD card. I've done a little basic low-speed SD card stuff + FAT once, that's all though.
Is this feasible with "PIC & 'C'" and - in an attempt ;) to save a lot of time searching - please does anyone have some relevent pointers/links?
Thanks.
Stephen.
Offline Rerouter
Re: Interfacing mass-produced camera chips
« Reply #1 on: May 18, 2018, 03:24:10 am »
For interfacing, have a look at mikeselectricstuff 's youtube channel, he goes into interfacing cameras. And heavily using the DMA functions to allow handling camera datarates on the cheap.
Still a 720p sensor will take a fair bit of bandwidth depending on your desired frame rate.
The following users thanked this post: 741
Offline amyk
« Reply #2 on: May 18, 2018, 04:17:04 am »
720p is considered low resolution for the typical smartphone camera modules which you would probably be fine with, and they're pretty cheap. The interface is likely to be MIPI CSI or perhaps serial, it is doable to "stream" data into an SD card if you get all the timings lined up just right. You'd probably want to compress the output, however, and that goes easily into the realm of custom SoCs --- 1280x720 60FPS 24bpp uncompressed video takes ~160MB/s which is far beyond what the majority of SD cards can do.
« Last Edit: May 18, 2018, 04:20:04 am by amyk »
« Reply #3 on: May 18, 2018, 08:21:12 am »
Compression is a good point, I seem to recall Microchip have libraries implementing that, though it might just be JPG.
Two other routes I'm considering
  • FTDI do a range of camera interface chips
  • Rasperry Pi - would the 'nano' suffice?
