So I'm working on a Pre-amp for a sensitive sensor. I'm currently measuring its noise floor using a spectrum analyser.
I've not done this test many times so bear with me, trying to get my head back into the game.
The amp is in a shielded metal box and power is supplied internally from 2 batteries through some linear regs providing a split rail supply. With the BNC inputs of the amp shorted to GND using 50
terminators and the output connected to the spec analyser, with the frequency span set to max (100kHz - its an old spec analyser), the noise floor looks greater than it does with the frequency span set to say 195Hz.
So does anyone with experience with this sort of test know: is the test invalid if you take a load of different measurements with the small frequency span up to the max bandwidth? (so: 0-195Hz, 195-380Hz, etc up to 100kHz)
I know it'll take a while to do it this way, lets say I have time.
cheers
