Author Topic: isolating S-params in PCB board  (Read 3370 times)
Offline gf
Re: isolating S-params in PCB board
« Reply #25 on: April 25, 2026, 08:14:00 am »
I know there is 2X method, 1x Reflect Method.
What method did he meant in his explanation?
I think AFR supports both flavors.
(BW is the frequency range of the VNA in use 43.5GHz for N5244B)
So, if you use N5224B. the minimum fixture  can be < 22pS
What makes you think that, when you follow the example calculation in the help text?
For example, a measurement at 26.5 GHz has a rise time of 37.7 ps. Therefore, the fixture length must be 4 * 37.7 ps = 151 ps.
1/43.5GHz * 4 = 92ps, or roughly 15mm, depending on the PCB material. Better use more than the absolute minimum.
