Talk to Indium Corp, they are more likely to have something then Kester.
In 60/40 Tin/Lead solder, fine gold fires dissolve amazingly fast, faster then you can see without a high speed camera. Twenty years ago, I had 40 modules with broken bond wires to repair, I ended up with ~25 working. The customer was thrilled even with that 50% rate of recovery, because this is a difficult task without the exact correct alloy.
I ended up with a home made tin/silver alloy that was less then optimal and turned grey when it cooled.
If I had to do it again, I'd certainly buy the correct materials.
1 mm wire has better far stability then the bonding wire, but I would still find the correct alloy.
Steve
