Author Topic: 3D Printed adapter for using 6mm knobs on 3mm shaft  (Read 1413 times)
Online mawyattTopic starter
« on: May 02, 2026, 01:50:46 pm »
Our Tek 577 and 177 arrived long ago with various problems, mechanical and electrical, most of which have been corrected. However, the 177 front has a couple rotary variable adjustments (pot and trimmer cap) that have ~3mm shafts, and the knobs we have on hand all have the larger ~6mm opening for the knurled pot shafts (no set screw). One of the original Tek knobs was useful (other was cracked with just the metal insert left) so we lived with an exposed shaft on one. Our intent was to 3D print another like Tek knob using the metal insert but misplaced such, which seems common now ???
Anyway, we decided to 3D print an adapter to allow the 6mm knurled knobs we have to be used with a 3mm shaft. This allowed us to use knobs on hand as shown, maybe others can benefit from this simple 3D  adapter.
Note: Change file name by removing .txt extension.
Best
« Last Edit: May 02, 2026, 02:17:38 pm by mawyatt »
~Wyatt Labs by Mike~
Online voltsandjolts
Re: Knob insert
« Reply #1 on: May 02, 2026, 02:08:01 pm »
Neat idea. May I suggest a slightly more descriptive title like
"3D Printed adapter for using 6mm knobs on 3mm shaft"
The following users thanked this post: mawyatt
Online Benta
Re: 3D Printed adapter for using 6mm knobs on 3mm shaft
« Reply #2 on: May 02, 2026, 05:04:16 pm »
Those can bought by the barrow on the market. Cost a few cents.
But nice little project.
« Reply #3 on: May 02, 2026, 05:16:01 pm »
I should have asked before doing the 3D print!! Took a couple hours (print/test/print) to get the size just right to fit :o
Anyway, gives a justification, excuse, need, requirement for having a 3D printer as explained to the CEO ;)
And it saved a few cents :-+
Best
Online Gyro
« Reply #4 on: May 02, 2026, 05:49:33 pm »
You should persuade him that you need to get a small lathe, to save time on adjustments, while you're on a roll.  ;)
Best Regards, Chris
Offline edavid
« Reply #5 on: May 02, 2026, 06:01:13 pm »
Where can I find them?
« Reply #6 on: May 02, 2026, 07:13:20 pm »
It's not a him, but a she ::)
Best
« Reply #7 on: May 02, 2026, 07:36:03 pm »
She, who must be obeyed.
Online Gyro
« Reply #8 on: May 02, 2026, 07:48:12 pm »
Aaah, you may have a bit more of a task explaining what a potent combination additive and subtractive machining is then.  ;D
Best Regards, Chris
Online 2N3055
  • Country: hr
« Reply #9 on: May 02, 2026, 08:07:23 pm »
Mine likes when I make and repair stuff arround the house..
She is more than happy for me to get tools, I then make something and its a win win
Even if it is a piece of furniture while I get audio analyser. She does not care.
Dr. Richard W. Hamming
