I am designing a sort of "fan out" board for various timing frequency sources - the kind that keeps lab full of gear in sync. I am finding out there is no agreed upon values and levels on these things, so I'm trying to accommodate most of situations. First in order is a unit that plugs directly into the frequency source to bring the output to usable level AND protect the source from reverse input.
For example, PRS-10 puts out 10MHz, 0.5Vrms, 1.41Vpp, and +7dbm (50ohm)
HP8644 expects 0.5Vrms (7dbm) to 2Vrms (19dbm)
Account for loss and mismatches, it seems prudent to provide 15db or so amplification, adjustable to 0db. That would probably mean using OP amp.
There are plenty of video amp that seem appropriate for this kind of use but problem is, almost all of them are surface mount. I would very much like to avoid this. So I'm looking for 8 pin can or DIP packaging. In addition to compensating for loss, I plan to use an attenuation and transformer to further isolate/protect the source. So minimum 20db of gain is necessary.
Given these parameters, can anyone give me a recommendation? This really isn't a distribution amplifier but sort of a buffer. So I don't mind spending few dollars on it. For distribution amps, I already have symmetricon set up.
