Can you please help me? I am stuck and don't know what I did wrong...
If I disconnect the TIC from ADC0 and measure the TIC output it looks like this
![Lars DIY GPSDO with Arduino and 1ns resolution TIC 2151925-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=93363.0;attach=2151928;image)
If I connect it to ADC0 the entire signal goes up 1V and looks like this
![Lars DIY GPSDO with Arduino and 1ns resolution TIC 2151931-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=93363.0;attach=2151934;image)
When connected the ADC0 reading is 1023 if I disconnect it the reading is ~200 and the console shows 10MHz?
Type f1 <enter> to get help+info
time ns dac temp status diff_ns filtX10 tc filt timer1 temp1
1 Missing 10MHz? 32768 25.8 WarmUp 1013 10230 32 1 46291 239 Five minute averages: TIC+DAC+temp
1 Missing 10MHz? 32768 25.9 WarmUp 0 10230 32 1 41521 238 Now acquiring value: 0
1 Missing 10MHz? 32768 25.9 WarmUp 0 10230 32 1 6677 237
1 Missing 10MHz? 32768 25.8 WarmUp 0 10230 32 1 41333 240 0 0 0 0.0
1 Missing 10MHz? 32768 25.7 WarmUp 0 10230 32 1 34487 240 1 0 0 0.0
1 Missing 10MHz? 32768 25.9 WarmUp 0 10230 32 1 6018 239 2 0 0 0.0
1 Missing 10MHz? 32768 25.7 WarmUp 0 10230 32 1 27025 241 3 0 0 0.0
1 Missing 10MHz? 32768 25.8 WarmUp 0 10230 32 1 40620 238 4 0 0 0.0
Is this the way the signal should look like? somehow I would expect it would slowly charge and based on how much it charged you know the delta... And since the TIC offset is between 200 and 1020ns I would expect the slope would be over this period....
