The 1u cap will be easy, polypropylene or polyester, use a 250V component and it will do with a quality brand unit like Epcos or Wima.
100uF units will be harder, but the same again about brand, and use low ESR units. Would probably be better to use 400V units, as these are available with high ripple current ratings and ultra low ESR as bulk power supply capacitors.
