My thinking is
A lot work and effort has already been spent on what has been built, so simple changes to get it to work proper. A new design from scratch has a lot of options, but is forgetting all the work already done.
Here the cube has already been built with a lot of work involved. It is a common cathode with each layer having a separate cathode line.
Next in time already spent is the latch board. The already built board for the latches is just missing an enable signal to 138 to cure that problem. It will still have the limited current output. With out rebuilding the cube, a high side switch is needed to increase current capability.
So a one wire fix is possible, and to use existing cable, the easy change is to move switch with 2 leds.
On processor board, I do not like the current transistor setup. So something needs done here, I think. With out changes to the cube, the design needs to handle 64 led's current use in a low side switch.
C
Hi again everyone, and once again, thank you very much for the detailed reply.
I think C is correct, I would much prefer to get the one I have built working and convert all of my learnings into building an 8x8x8 RGB
why?? I don't really know..
I think my things to work on are as follows,
1 - Fix the issue and enable pin with the 138 and check overloading on the 574s.
2 - Install Darlington quads to replace the existing 2N2222 set up.
3 - Revisit the software and tidy it up.
Yes, I am currently working with the instructables software as it is. So I will be working throught it. Would you mind just giving me a really quick rundown on what each file is responsible for?
Going over the schematic, they are relying on the micro outputs to bias the transistors off. Since you have said you are using 4k7 resistors for the 2n2222 I would replace them with 1k. This should turn the transistors on and off quickly, instead of having the lag or ghosting. Have a look at the comments in the project someone also mentions to use lower value resistors.
Hi Strada916,
I just wanted to check that you mean a value of 1k for the pull up resistors? I have 1k base resistors already installed. I haven't seen any pull up resistors that low if thats what you mean. Would be interesting to find out why that would work better.
Thanks again everyone, I really appreciate it.
Lee
