Author Topic: LiFePo4 Chargers  (Read 1161 times)
Offline cRash1001Topic starter
  • Country: np
LiFePo4 Chargers
« on: March 29, 2023, 06:28:22 am »
I need to charge 5 14.4V LiFePo4 batteries in parallel and am l looking for chargers that can be easily mounted and hopefully have access to the Charging Status LEDs.
The requirement for the charger are:
1. Charging current > 2A
2. Indicators to show status -> Charging -> Charged -> Fault
3. Easy to Mount -> DIN Rail or Open Frame or anything that can be mounted
I have encountered some Deskop / Power Brick type chargers but haven't found chargers that can be mounted inside a box. It would be really helpful if anyone could suggest some good chargers.
Offline TruslowPJ
Re: LiFePo4 Chargers
« Reply #1 on: March 29, 2023, 04:26:04 pm »
I have a Noco genius 5 charger that supports 12V lifepo4 batteries. It comes with a mounting bracket, and the included cable uses battery clamps that attatch using ring terminals, so all you need is a screwdriver to convert from clamps to ring terminals. It is meant more as a jack of all trades charger rather than a dedicated lifepo4 charger, but always auto detects lifepo4 batteries for me somehow so I don't have to set the mode.
