Author Topic: Limit switch - help find one  (Read 3481 times)
Offline metRo_Topic starter
  • Country: pt
« on: August 28, 2013, 10:11:47 pm »
I'm looking for a limit switch but it won't cut a power source connection. I'll use it as a input for microcontroller to know when a moving piece reached the final position so I don't need nothing rated for several amperes. The smaller one I found is http://www.e-switch.com/product/tabid/96/productid/94/sename/ts-series-sub-miniature-snap-action-switches/default.aspx#ex1
Do you know any other options like that or smaller? Another option are the ones used in cdrom/dvd players but I can't find a image of them right now but they are just a plastic piece hold two pieces of copper, do you know them or how they are named?
Thanks
(sorry my english :s)
Re: Limit switch - help find one
« Reply #1 on: August 29, 2013, 04:38:11 am »
You will not get microswitches much smaller than that, and if you want leaf switches I would just gut a few CDROM drives for the tray switches, and use them.
If you need a precision switch then it will be a lot more expensive, depending if you are happy with a final position error in the order of 0.5mm or not. If you want a very precise switch they do become rather expensive as you go to finer and finer resolution.
  • Country: pt
« Reply #2 on: August 30, 2013, 12:22:10 am »
thanks, the term "leaf switch" will help me :)
Offline george graves
« Reply #3 on: August 30, 2013, 05:44:10 am »
You can also use a hall effect switch.  Such as:
There are from  reprapdiscount on ebay.
  • Country: pt
« Reply #4 on: September 09, 2013, 10:49:33 am »
Thanks, but I need something small:)
« Reply #5 on: September 09, 2013, 12:25:34 pm »
The hall effect sensor is a t-92 package(I'm sure you could extend them off the board).  And those tiny magnets are tiny.  Can't get much smaller I'm afraid.
Other wise you might look for a momentary tactile switch with only 2 pins.  They are half the size of a normal tac switch.
« Last Edit: September 09, 2013, 12:28:12 pm by george graves »
