I want to make a lab/bench "workhorse" power supply. Not too noisy, so linear rather than switching, and high power so
as to utilize a 2x25V 500VA toroid transformer that I have. Precision would be nice, but initially the emphasis is on power.
So I've been investigating putting linear regulators (eg LM350) in parallel for increased current output, and according to LTSpice, looks to be quite doable.
In practice, there will be a pre-regulator ahead of this, but here I'm just playing with the main regulator part.
The schematic I've come up with (using Lx317's):-
The output voltage is controlled in the usual way via the value of resistor RVAdj, with the usual lower limit of 1.25V.
The ballast resistors can also double as current sensors.
Sweeping the adjustment resistor to cause an output range of 2V to 30V, with a 5R load.
Here the output voltage is set to 12V, while the load ranges from 2R to 20R.
The start of the simulation is confused with the heavy starting load, but the load regulation is pretty good once it gets underway.
But I messed around some more to try for current limiting, and output down to 0V, and both operated via control voltages.
Adding some underground opamps, resistors, diodes and voltage sources, we have:-
Sweeping the Voltage control with a 5R load and current limit set to 5A:-
At 24V output, sweeping the load from 2R to 20R, with the current limit set to 4A:-
With 18V output into a 6R load, sweeping the current limit from 1A to 6A:-
This seems to be a cheap and cheerful way to get a reasonable high current, linear regulator with voltage driven controls.
Or not?
I'm going to knock this up with LM350s soon, and see how the reality pans out.
