Author Topic: Linear technology power supply design  (Read 3556 times)
Offline qpit3aTopic starter
  • Electronics hobbyist.
    • Not really about trains
« on: October 13, 2014, 12:30:28 am »
I was sent this design from Linear Technology for a power supply that I think is interesting as it has 3A output capacity from linear regulators without heatsinking and without large capacitors.
https://drive.google.com/file/d/0Bz-LaovGlmDOa1d0ak5xOHhyMGM/view?usp=sharing
Peter Cupit
Offline Marco
Re: Linear technology power supply design
« Reply #1 on: October 13, 2014, 12:56:54 am »
I get that they want to push their ICs, but the two parallel linear regulators I find a bit iffy.
« Reply #2 on: October 13, 2014, 02:16:21 am »
Perhaps this idea of the parallel regulators could allow easy design alterations to allow larger current supplies to be built.
My main interest would be to see if all the components could be obtained for a through hole implementation and if it could then be made cheaply without a pcb...
The populated board turns out to be $200 from LT...
« Last Edit: October 13, 2014, 02:36:30 am by qpit3a »
Peter Cupit
Offline Smokey
  • Not An Expert
« Reply #3 on: October 13, 2014, 02:30:50 am »
I bet they are showing two parallel linear regulators to point out the fact that you can do that.  Unless you matched old 7805s, if you put them in parallel one would take all the current and overheat.
That's cool that they made the new chips parallel-able.
Tac Eht Xilef
  • Guest
« Reply #4 on: October 13, 2014, 03:16:28 am »
AFAIK only the LT3081 comes in a TH (TO220-7?) package.
c.f. This earlier discussion on the LT3081, which includes a similar circuit.
Offline nowlan
« Reply #6 on: October 13, 2014, 03:25:15 am »
Thanks, should have checked.
Peter Cupit
Online David Hess
  • DavidH
« Reply #7 on: October 13, 2014, 06:06:59 am »
It is no more iffy than using parallel output transistors.  In both cases resistive ballasting is used to enforce current sharing even if that only exists in the output resistance of the devices and the circuit wiring.
