Hello battery experts.
I have a project where I am using a 5000mAH (flat pack) LiPo battery from a seller on Aliexpress.
I am attempting to charge it with a 5V 1A TYPE-C Micro USB 18650 TC4056A Lithium Battery Charging Board also from Aliexpress.
I have used several of these boards in other projects but always charging lower capacity Lipo batteries e,g 650mAH and 100mAH without any issue.
Normal operation:- When charging there is a red LED on the charging TC4056 pcb that is lit whilst charging. As the battery voltage reaches 4.2V the charger stops charging,
the red LED goes out and a blue LED illuminated to indicate that the battery is fully charged.
The problem:-
When charging this new battery, the TC4056 board charge current is adjusted to 1/2C (500mA) but the battery the voltage NEVER reaches 4.2V.
Consequently the charger never switches from red to blue to indicate fully charged. So without connecting external DVM's I don't know what state of charge the battery is in!
It could be almost 'flat' or have a full amount of energy.
The clues:-
Whilst monitoring both charging current and battery voltage simultaneously I have noticed that as the battery voltage approaches between 4.05 and 4.1V (never a precise set point) the charging current keeps
intermittently falling to a low level or dropping to zero, and then almost immediately jumps back up to full charge current.
It's as though the BMS (Battery management/protection system) pcb built into the battery, is intervening in the charging process and preventing the charging from ever completing?
Questions:
Has anyone else seen this strange behaviour?
Does it look like I have a faulty battery or am I missing something?
I could live with 4.1V for this application but I can't see a way to 'fool' the TC4056 into thinking the battery is fully charged.
There is a Texas LiPo charging IC that has a switchable 4.06V or 4.2V 'set point' but no cheap modules available sporting this chip!
I am loathe to buy a second battery (from a different vendor) until I understand what is causing this phenomenon!
It's a mystery.
All help/comments appreciated.
Thanks in anticipation.....
Dave
