Hi all. It's been a while since I last posted. A friend of mine gave me a crapload of integrated circuits in plastic tubes, about 130 different kinds. (I'll make another post later about what they all are.) It took a while but I tracked down datasheets for nearly all of them, but there's a few that I've had little to no luck finding a datasheet or even any clues as to what they are no matter how much searching I've done on every datasheet website I can find. I'll attach a scan of all their markings. Here's what I have so far:
Teledyne 741CP: might be an opamp similar to the Harris CA741E and National Semiconductor LM741C
Synertek 2111-1: possibly a 256x4 static ram; the bottom is marked F3052-2/404ES; Synertek seems to no longer exist
Philips 215CN: the bottom is marked "PHIL" so I'm assuming it's Philips; might be a phase-locked loop similar to the Exar XR215
Teledyne 301CJ: might be a resistor array, high speed analog switch, or a NAND gate
Teledyne 302CJ: might be a NAND gate
Teledyne 351CJ: no idea
Teledyne 361CJ: a translator (?)
Teledyne 380CJ: might be a decoder of some sort
Teledyne 723CJ: might be an adjustable positive voltage regulator if it's similar to the Texas Instruments UA723
Motorola MC1020P: might be a 3-input OR/NOR gate
Fairchild UC961659: no idea
NE5558V: the logo might possibly be System General; my best guess is that it's related to the 555 timer
Can anyone provide some help in tracking down what these are? They all have date codes from the 70s and 80s.
Thanks!
