Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
LM13700 as Voltage controlled resistor wrong values
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LM13700 as Voltage controlled resistor wrong values (Read 1133 times)
nhouza
Newbie
Country:
on:
January 22, 2022, 09:18:19 pm »
Hello. I'm having trouble to figure out why my calculations don't match the measurements when I hook up a LM13700 as Voltage controlled resistor.
Similar issue for both configurations: single ended or floating.
as for
[url=https://www.ti.com/lit/ds/symlink/lm13700.pdf]https://www.ti.com/lit/ds/symlink/lm13700.pdf] [url]https://www.ti.com/lit/ds/symlink/lm13700.pdf]https://www.ti.com/lit/ds/symlink/lm13700.pdf]https://www.ti.com/lit/ds/symlink/lm13700.pdf] [url]https://www.ti.com/lit/ds/symlink/lm13700.pdf
[/url]LM13700 Datasheet (fig.28, Floating Voltage-Controlled Resistor)
THEORY:
the formula given is Rx= (2 * R)(gm * RA) , where gm is 19.2 * Ibias
In my calculations,
Ibias is max 0.42 mA
Ra is 1K
R is 100K
The Rx resulting should be 24.8 K and for descreasing Ibias, Rx goes up.
PRACTICE: By following the circuit ,
i feed max 0.42 mA at Pin 1 and 16 of the LM13700 and i set up a simple voltage divider to test it in practice as follows.
Vin is 5.19 V, R1 is replaced with the LM13700 and r2 is 100k.
Following the theoric calculations, i should expect Vout =4.16.
But what i can measure in practice is 3.36V though.
Do you have any suspects if I'm doing something wrong or hints to give?
I take for granted that Ibias of 0.42 mA that i split between pin 1 and 16 of the OTA, has to be used as it is in the Formula ( and so i don't have to use 0.42mA/2)
Thanks a lot for any advice or help.
Last Edit: January 22, 2022, 09:21:18 pm by nhouza
Logged
moffy
Super Contributor
Country:
Re: LM13700 as Voltage controlled resistor wrong values
Reply #1 on:
January 22, 2022, 09:56:25 pm »
The spice model for the LM13700 can be downloaded from:
https://www.ti.com/product/LM13700#design-development
if you import it in LTSpice it will give you a cross check on your calculations and measurements.
Logged
nhouza
Newbie
Country:
Reply #2 on:
January 23, 2022, 03:12:14 pm »
Thanks for the hint.
Then I have done a simulation for the first time with LTspice. So, please excuse me if I mistake something.
This should be easier to understand than my monologue above.
I attach the files for this simulation if you are interested (i guess they are enough to run it).
It looks to me is that my practical measurments match the LTspice simulation since i get 3.2V at the output (almost 3.34 that i measured).
So, I'm wondering what I'm doing wrong in my theorical calculations.
I'm missing a very stupid point somewhere but I can't figure it out.
Logged
moffy
Super Contributor
Country:
Reply #3 on:
January 24, 2022, 12:40:53 am »
Nice job on your simulation.
For the resistance calculation: Rx = 2*R/(gm*Ra) with R=100k, Ra=1k and gm = 19.2Iabc or gm= 19.2*210u
so Rx = 200/0.004032 = 49.6k which is consistent with the results you are getting. You are getting roughly 2/3 of the 5.19v across the 100k resistor when Iabc = 210u or 420u/2.
Last Edit: January 24, 2022, 01:17:30 am by moffy
Logged
nhouza
Newbie
Country:
Reply #4 on:
January 24, 2022, 11:52:29 am »
That's it!
TI datasheet's formula means Iabc to be halved prior to stick that into the formula.
I thought about that at the beginning but i thought that would have been stated on the datasheet. That particular one looks quite tricky to me.
from the very most precise calculations i can do, from the simulation I still measure 3.491V instead of 3.469V expected from the theoric calculations. This is of course a ''good enough'' but is quite irritating since should be pure math and both Ltpisce and formulas exclude components tolerance.
I also discovered that the first spice model that i used (found here
https://github.com/deanm1278/LM13700-spice-model
) is not quite well performing.
The original TI is the most accurate (and it makes sense).
Both simulations attached.
thanks a lot @moffy
Logged
moffy
Super Contributor
Country:
Reply #5 on:
January 24, 2022, 12:29:45 pm »
Glad to be of help.
Logged
nhouza
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
