Author Topic: Load detection  (Read 3993 times)
Offline bmarvoTopic starter
Load detection
« on: May 29, 2012, 07:01:56 pm »
Okay so I'm designing a portable cell phone charger with a battery pack. What I want to do is detect when the phone is connected so I can turn
on an LED indicating whether or not the battery has sufficient charge. I immediately think that current sensing on the output is the way to go.
So I found this device: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00283176.pdf
I could use something like that with a comparator to detect when the load is attached. It does seem like overkill using a precision device.
Anyone know of a more elegant solution?
Here is an image of a very basic version of what I'm talking about.
Offline chrome
Re: Load detection
« Reply #1 on: May 29, 2012, 07:53:16 pm »
Small resistor in line with the power supply going to the phone, measure over this resistor with a opamp in differential mode, feed this to a comparator, done.
Re: Load detection
« Reply #2 on: May 29, 2012, 09:08:12 pm »
Excellent. Prototyped it and it does the job
Offline T4P
  • Country: sg
    • T4P
Re: Load detection
« Reply #3 on: May 30, 2012, 03:29:08 am »
What chrome said is basically a current shunt monitor ... like a INA168
His solution is cheaper  :)
Offline cebrax
  • Country: tr
Re: Load detection
« Reply #4 on: September 16, 2012, 08:21:41 pm »
I am really interested in this. I want to make a detector to detect IC insertion into an 8-pin DIP socket. Whenever the IC is inserted, I want to sense if there is any current flowing into this IC's Vcc pin, and so I will be able to detect an IC insertion (or call it a load connection). However, I want to build this only with transistors. Is this possible?
Online AndyC_772
Re: Load detection
« Reply #5 on: September 16, 2012, 08:52:40 pm »
Depends on the IC. If it's a CMOS gate, for example, there could be so little current that measuring it could be a real challlenge whatever components you decide to try and use.
Do you have a specific IC in mind?
Offline cebrax
  • Country: tr
Re: Load detection
« Reply #6 on: September 17, 2012, 07:27:36 am »
Yes, I think it is a CMOS IC. I have a specific IC in mind, X9C102P, but I don't want this detector to be working for only this specific IC, that means I do not want to detect it polling other pins.
