Author Topic: Load efficiency  (Read 1895 times)
Offline keshab.patelTopic starter
Load efficiency
« on: May 02, 2015, 10:44:45 am »
 I am working on a rfq where three parameters are there. Nominal load, load efficiency and resultant load. Where resultant load= nominal load *load efficiency. So what is this load efficiency and how does it affects to search a connector or fuse for that load. Please help.
Offline Psi
Re: Load efficiency
« Reply #1 on: May 02, 2015, 10:49:43 am »
We need more info. What kind of load is this etc...
Re: Load efficiency
« Reply #2 on: May 04, 2015, 04:48:31 am »
Its a power distribution module. and there are all kind of load from motor, solenoid to resistive load. And the power has gone to different ecu. So hard to tell which one is which load.
Another thing is what is "take rate " of a connection.
