Author Topic: Looking for a current limited high side driver/load switch 30V and 2-4A  (Read 1873 times)
Offline AndersJTopic starter
I need a fast electronic current limiter, a ”fuse”, but ”fast” and autorecoverable.
A high side switch, at least 30V, 2-4A, thermally protected,
with automatic reconnection attempts every nn seconds would likely work.
The ST VNI2140 is perfect, but the current limit is too low.
I tried parametric searches on Mouser and Digikey, but my search skills are limited.
Any suggestions?
"It should work"
R.N.Naidoo
Offline Scrts
  • Country: lt
The following users thanked this post: AndersJ
Re: Looking for a current limited high side driver/load switch 30V and 2-4A
« Reply #2 on: November 03, 2021, 02:09:28 pm »
The TPS1H200A seems to be a excellent choice.
Many thanks for the suggestion.
Now I need to figure out where to buy it.
Stock seems to be zero everywhere  :(
"It should work"
R.N.Naidoo
« Reply #3 on: February 22, 2023, 04:02:46 am »
16 months later, and still unobtanium 🙁
Does anyone have an alternative suggestion?
"It should work"
R.N.Naidoo
Offline thm_w
  • Non-expert
« Reply #4 on: February 24, 2023, 12:09:20 am »
Its worth your time to learn how to search digikey, instead of waiting 16 months.
https://www.digikey.ca/en/products/filter/power-management-pmic/power-distribution-switches-load-drivers/726
https://rocelec.widen.net/view/pdf/mhyxqjr8f0/FAIRS46409-1.pdf
