I need a long gear for a project, im sure theres a name for what i want but i havent been able to find anything.
It needs to be like a cylinder with teeth going lengthways, the opposite of a worm gear almost. the rest of the project can be adapted to its pitch diameter etc. Preferably a diameter of 35mm and about 10cm long.
i have though of getting it custom made but im sure somebody would sell something like this..
Look up timing belts or pulleys and you/ll find something like
this:
is this what you're after?
yeah pretty much that but it needs to be able to mesh properly with a spur gear. the thread on that looks more rectangular
Does the word "pinion" help?
Do you need one for a one-off project, or a supply of them for production? it makes a difference. Also you describe the gear as "tall" but specifiy 10mm thick by 35mm DIA... which seems short and fat. Is the difference semantics? or a typo? I guess relative to a lot of things I see 10mm thick would be unusual but I just wanted to make sure.
i think daveW wins this time, thanks mate
