Author Topic: Looking for PCB mount BNC plug  (Read 408 times)
Offline jbbTopic starter
« on: April 29, 2024, 08:13:27 pm »
Hi all
I may need to make up some oscilloscope adapters (filter + termination). I want to make a small PCB which mounts straight onto my oscilloscope input.
Does anyone have good options for a PCB mount BNC plug?
Offline jwet
Re: Looking for PCB mount BNC plug
« Reply #1 on: April 30, 2024, 09:18:44 pm »
I ran into this problem a while back.  They are somewhat rare but not impossible.  I never found a reliable source for production but I was just making lab stuff and found a couple solutions.
One place they are used in twisted pair coax balun type transformers used for CCTV systems.  These are cheap enough that you can buy them from china and take the bits you need.  See photo.
I also made a few adapters from BNC T's and L's and a few minutes with a dremel tool.  Don't have a great picture but attached what I could.
Below is a quick picture of both. Top is label from bag that Balun, left, came in- MC Electronics is a low tech electronic distributor in the US but these can be found elsewhere.  Right is a little project that has a 20 Mhz crystal and an NE-602 mixer that was a receive converter to get 162 Mhz Weather on a 2M radio.  I've used it for years and its pretty beat up.  9v battery on clips and BNC directly into radio- carved the adapter with dremel wheel to expose center core and outer cylinder.  Soldered up pretty well
« Last Edit: April 30, 2024, 09:21:41 pm by jwet »
Offline thm_w
  • Non-expert
« Reply #2 on: April 30, 2024, 09:28:18 pm »
For hobbyist uses, tons are available on aliexpress:
https://www.aliexpress.us/item/4001045414672.html
https://www.aliexpress.us/item/1005003918622626.html
Another option is to use SMA through hole connectors, which are even more commonplace, and then a BNC adapter.
Offline David Hess
  • DavidH
« Reply #3 on: April 30, 2024, 10:48:51 pm »
I have a bunch of BNC-male to BNC-male adapters that I use instead.
« Reply #4 on: May 01, 2024, 04:06:30 am »
Thanks all
Good idea on the Balun boxes, but I don’t have any lurking around.
Will probably proceed with an SMA approach and SMA-BNC adapters for the scope (which are useful to have around anyway).
