Author Topic: Looking for recommendations: fast 50 Ω TTL pulse-output driver  (Read 1462 times)
Offline Smile2016Topic starter
I'm looking for a fast pulse-output stage driven by a 3.3 V CMOS FPGA, for a rear-panel BNC on a test instrument.
My Requirements:
Input: 0–3.3 V CMOS from FPGA
Pulse width: 10 ns to 2 s, 10 ns increments
Output: TTL-compatible into 50 Ω
Rise/fall time: ~2 ns
Supply:  +5.00 V [or 15V available ]
Connector: rear-panel BNC
I do not need a real 5 V across the terminated 50 Ω load. A conventional 50 Ω source-terminated output is fine:
~5 V driver ── 50 Ω ── BNC ── 50 Ω load ≈2.5 V HIGH
This requires roughly 50 mA drive, while providing ~5 V into high-Z and ~2.5 V into 50 Ω.
The FPGA generates all pulse timing; the output stage only needs to preserve the 10 ns minimum pulse width and ~2 ns edges.
ICs currently being considered, have them around:
SN74LVC1G126  simple and fast, but 3.3 V input level compatibility is an issue when powered from 5 V ??
TLV3601  very fast comparator can define ~1.65 V input threshold, maybe hysteresis but likely insufficient current for directly driving the 50 Ω source-terminated output.
I'm also curious  about modern single-channel IC or simple topology capable of approximately 50–60 mA at 5 V with ~1–2 ns edges
Since this is an exposed rear-panel BNC, ESD, short-circuit and accidental external-voltage protection are also "required" without significantly degrading the edge rate.
Any recommendations for a suitable driver IC or proven topology? such as 1PPS drivers around here but nicer :) Cheers !
Online moffy
Re: Looking for recommendations: fast 50 Ω TTL pulse-output driver
« Reply #1 on: August 19, 2026, 10:32:09 am »
I've used the 74ALVC14 for sending a 50MHz square wave, differentially, down 50 meters of CAT5. If you used one of the 6 inverters to drive the other 5 in parallel it should work and maintain phase.
The following users thanked this post: Smile2016
Offline langwadt
« Reply #3 on: August 19, 2026, 11:30:42 pm »
Not sure the 74ALVC14 will handle TTL levels properly.  It’s almost there.... I’d also need to daisy-chain two stages since I don’t want the signal inverted. it is an instrument pulse output ... I do not control the polarity....
« Last Edit: August 19, 2026, 11:46:38 pm by Smile2016 »
« Reply #4 on: August 19, 2026, 11:46:00 pm »
Interesting device, the 74ACT17. I’m no longer sure I really need those ~2 ns fast transition times. The ACT17 may actually work, I can’t determine the output rise/fall times clearly from the datasheet.
Offline MarkF
« Reply #5 on: August 20, 2026, 12:46:43 am »
Have you seen this:
  https://www.eevblog.com/forum/projects/compact-74ac14-pulse-generator-pcb/
You would have to check that 3.3V will trigger the input.
Offline langwadt
« Reply #6 on: August 20, 2026, 08:34:44 am »
 74ALVC is 3.3V only, you need something with either a "T" for ttl or dual supply, to get both 5V output and 3.3V compatible input
Offline Terry Bites
« Reply #7 on: August 21, 2026, 09:40:36 am »
Clock buffers?
The lore says you cant parallel up logic outputs for more current even if you're sensible and sum them resistively.
The risk of jitter is high, but what if that level of jitter is acceptable?
I've seen the lore broke and been gotten away with many times, I'd say its worth a punt.
Offline Andree Henkel
« Reply #8 on: August 21, 2026, 02:42:43 pm »
real 5V across the terminated load is not TTL, and it cannot be done with 5V driver supply
TTL is >=2V at the 50Ohm terminated load, that can be done with 5V driver voltage, even if there is 50Ohm source resistor
to get 5V across 50Ohm term you need > 10V if you also source terminate with 50Ohm, with your 15V there should be a way
« Last Edit: August 21, 2026, 02:45:37 pm by Andree Henkel »
Offline mtwieg
« Reply #9 on: August 21, 2026, 03:44:22 pm »
The AHCT logic family works well for converting 3.3V to 5V. But when loaded the actual output swing will be decreased. For example a single buffer (SN74AHCT1G125) will swing within 0.1V of either rail with light load (<50uA), but with a load of 8mA might only get within 0.5V of either rail. So you would need to stack many in parallel (maybe ten or so).
« Reply #10 on: August 21, 2026, 04:40:16 pm »
mentionet initially : "I do not need a real 5 V across the terminated 50 Ω load. A conventional 50 Ω source-terminated output is fine:
This requires roughly 50 mA drive, while providing ~5 V into high-Z and ~2.5 V into 50 Ω."
Offline David Hess
  • DavidH
« Reply #11 on: August 21, 2026, 09:15:33 pm »
The 74LVC125A is my go-to fastest 5 volt part for general purpose interfacing.  The 3-state output can be used as a push-pull output, or a pull-up or pull-down open drain output.  Unfortunately it is probably not going to work well with a 3.3 volt input while supplied by 5 volts unless you do something exotic, so my next choice is the 74ACT125 which will accept 3.3 volt logic and produce a 5 volt output
The exotic thing to do is operate a 74LVC125A with a 3.3 volt supply so that its input will accept 3.3 volt logic, and then use it to drive the emitter of a bipolar transistor on the output to do a 5 volt level shift with a 5 volt pull-up.  This will produce an incredibly fast output, and one of the reasons I morn the loss of fast PNP bipolar transistors.
In the past, 50 ohm line driver TTL parts like the 74AS140 and 74F140 would have been my choice.
« Last Edit: August 21, 2026, 09:36:44 pm by David Hess »
Offline ConKbot
« Reply #12 on: August 22, 2026, 02:24:55 am »
SN74LXC1T14 looks silly fast, supports 32mA outputs (parallel 2 and use 100 ohm series term on each so your BNC sees an effective 50 ohm output impedance)  and has independent power supplies, with good behavior when partially powered. Schmitt trigger input could be a bit messy with the logic state not matching if your input signal is slow, but most FPGA outputs are annoyingly fast,even on slow slew rates, so just route your transmission line well to not make a ringy mess going into the pair.
« Reply #13 on: August 24, 2026, 03:07:22 pm »
Got a quick test done with the "analog" version using a TLV3501, with some hysteresis added as well. My only concern is that the pulse width seems slightly longer than the 10 ns I applied from FPGA. That’s probably correctable by adjusting VREF, but I haven’t tried that yet. It’s currently set to 1.65 V, half of the FPGA’s 3.3 V supply. I also have my <2ns edges [1.4ns] and enough amplitude into 50 Ohms. For the rest I blame my cables....
