Hi electrotechnicians, new here and new quite new to ele too..
..so bear with me, please
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/xgrin.gif.pagespeed.ic.QVVz6XIT20.png)
bottom line: I want and advice to which type of circuit to pick to be able to pass EMC testing more easily...than the other alternative.
circuit purpose: to control resistive load power. load nominal operational voltage is 220VAC and it's 200W thing. A heater.
the two alternatives I have (or have come up with) are:
a)
diac controlled triac. Opto-diac is being controlled by microcontroler (arduino) which is sensing the AC phase, so it basically knows when will triac trurn off and it is turning the diac on to turn the triac on based on program/preference of such phase shift.
schema I found online:
![lower noise AC regulation circuit variants 1822789-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=384277.0;attach=1822792;image)
b)
PWM controlled MOSFET on the low side that open-closes rapidly and controls the effective voltage (rectified) on the load that way:
![lower noise AC regulation circuit variants 1822783-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=384277.0;attach=1822786;image)
please, assume some similar conditions for both circuits: the same load, the same mains, 2 layered PCB and some wires to the load...some reasonable conditions that are real enough and we can work this thought experiment out with.
hope it's enough for the starter,
thanks
