Author Topic: Lowest offgassing commodity PCB material for heating elements?  (Read 667 times)
Offline incfTopic starter
  • ASCII > UTF8
Do any commodity/cheap PCB materials exist that outgas significantly less than others when used as a heating element?
Flex PCB material (which is Polyimide I think) comes to mind. But I don't know for sure. Maybe somebody here would know.
edit: max temperature: 100C/212F
« Last Edit: April 15, 2025, 11:01:10 am by incf »
Test
Offline Conrad Hoffman
    • The Messy Basement
Re: Lowest offgassing commodity PCB material for heating elements?
« Reply #1 on: April 15, 2025, 03:08:16 am »
You might find something here- https://www.rogerscorp.com/advanced-electronics-solutions/rt-duroid-laminates
Probably not cheap and you don't want to be using PCB as a heater at particularly high temperatures.
