Hi All,
A beginner learning about opamps and this article seem to have caught while i was searching for examples and looked like a perfect fit for my project as well. I wanted something that could rectify the ac signal without any voltage drop and this seems to be ideal.
As mentioned in the article here
http://www.linear.com/solutions/1608 the LT1078 can be setup to rectify an AC signal.
The working mentioned in the article:For negative inputs, the first section operates as a closed-loop inverter (A=-1) and the second stage is simply a buffer for the positive output. When the input signal is positive, the first opamp output remains saturated near ground and the diode becomes high-impedance, allowing the signal to pass directly to the buffer stage non inverted. The composite effect is a full-wave rectified waveform at the output of the buffer.
The design as it is works and it was something that i had picked up quite well but am trying to use (as well learn about the opamp working) it as differential opamp without loosing the rectification unfortunately i loose one half of the cycle. Maybe dave (@EEVblog) could explain it a bit more in his upcoming videos.
Would appreciate if somebody could help me understand this.
