Ah! the plot thickens.
The LT3085 does have a modification on the SET pin that the LT3080 does not have.
Take a look at Note: 7 on both datasheets:
-gone-mad/?action=dlattach;attach=43024)
It looks like the LT3080 has the SET pin clamped to the output internally with diodes?
Can anyone test this? it would be interesting to see if these are Schottky or conventional diodes, and if there are back to back diodes.
The LT3085 adds 1k resistors (plural).
This almost certainly means the SET pin goes to two 1k resistors - one of which goes to the opamp input, and one goes to the 10uA current source. Then both the opamp and current source circuits are individually diode clamped so they cannot go more then a diode drop negative of the OUT pin. Using two 1K resistors eliminates any loss of regulation from the addition of the resistors, and means the SET pin can now safely go higher or lower then the OUT pin by +/- 10V.
It would be nice if you could add the same circuit externally to the LT3080, but you cannot as you cannot separate the current source from the opamp input.
If the LT3080 does have back to back diodes internally to OUT, then the really important spec becomes the +/- 10mA limit on the SET pin current. If you have, say, 10V on the SET pin and the output gets shorted, your circuit has to ensure that the maximum current into the SET pin is less then 10mA. Same story if the load actively drags the OUT pin up to 20V. Failure to ensure this in the design could lead to chip latchup.
Here is the circuit that LT meant to put into the LT3080 datasheet:
-gone-mad/?action=dlattach;attach=43026)
(Note to LT - you have my permission to this image directly into an updated datasheet.)
And the +/- 0.3V ? If they use internal schottky diodes, then I guess +/- 10mA may equal +/- 0.3 volts. Definitely if SET gets to one standard diode drop below the substrate (OUT Pin I guess) on the LT3080 and the LT3080-1, latch up could probably occur. The LT3083 and LT3085 would need the SET pin to be dragged over 10V below OUT for this to be a risk.
A BIG problem with their datasheet is that they allow for a 1uF cap to be put on the SET pin to reduce noise. If the output gets shorted, there is no possible way to keep the SET pin current below 10mA with a 1uf cap directly on the SET pin. FAIL!!!!!
So can someone do the test on a LT3080 to see what is between SET and OUT?
Richard
