http://www.eleccircuit.com/lm317-lm338-lm350-current-regulator-calculator/ its this but the resistor is 1ohm
i know i am using another regulator for the variable out put voltage and that works fine. I am using the 317 as the current regulation
Quote from: House91320 on May 29, 2011, 11:38:13 pmi know i am using another regulator for the variable out put voltage and that works fine. I am using the 317 as the current regulationAnd we are now supposed to beg you to give us the complete schematic? From my point of view, you either show us the real and full schematics, and you write a useful problem description, or you can stick it where the sun doesn't shine.
